Prevent phpBB 'code' tag from eating leading spaces?
stuart
Unread postby stuart » Thu Jan 31, 2008 4:24 am
As noted here, phpBB's 'code' tag removes any leading spaces from a line - which, for code, is almost definitely not what's wanted.
Is there any phpBB setting which can be hacked/changed to preserve all line-spacing within 'code' tags?
ShadeOfBlue
Re: Prevent phpBB 'code' tag from eating leading spaces?
Unread postby ShadeOfBlue » Thu Jan 31, 2008 5:30 am
It seems to work fine here (Safari 3.0.4) ...
. -> no leading spaces
  . -> 2 spaces
    . -> 4
        . -> 8
                . -> 16
What browser are you using? It's possible it doesn't have support for the CSS white-space property or that it in some way alters the text you enter.
stuart
Unread postby stuart » Thu Jan 31, 2008 10:37 am
Interesting - I can see spaces in your reply...
I pasted in the output from 'diff' in the post above (http://forums.nekochan.net/viewtopic.php?f=15&t=16878) with neko_firefox-2.0.0.11, and I can't see any leading spaces!
Unread postby nekonoko » Thu Jan 31, 2008 1:41 pm
I haven't noted any problems with it either - otherwise all of the 'hinv' outputs would look funny, and they're all fine.
stuart
Unread postby stuart » Thu Jan 31, 2008 4:36 pm
It must be something about the characters in the text, then (the troffrc file does tend to look like line-noise ;) ) - I've just re-edited the post with Safari, and the message body definitely contains leading spaces... which the rendered version definitely doesn't.
So there's definitely something wrong here - but it's something which doesn't affect hinv posts or SOB's post above.
. <- test 0
. <- test 0
 . <- test 1
 . <- test 1
  . <- test 2
  . <- test 2
Ah-ha! There we go! Single spaces at the start of lines in code blocks are being dropped!
Return to “Nekochan Net”
