Forum with Netscape 3 ?
escimo
Unread postby escimo » Sun Jun 18, 2017 3:41 pm
Does Nekochan forum have a simple method of presenting their web sites, like WAP, as well?
Try to open the forum with Netscape 3 from an i486 under Solaris 2.4 x86 and it didn't work (Bad req err code 400...). After some google usage should be problem with cookies. Found no way to dissable cookies under Netscape 3 after all. :mrgreen:
One option could be to upgrade to Netscape 4. Because it's already damn slow with N3 it can't getting more worse with N4, I hope.
Option two is to switch to text based browsing (e.g. lynx). Anyone here who browsing through Nekochan forum with text browser?
SNI: PCD-4H (sphinx), PCD-3Msx (cupido), SCENIC Pro C5 (scenic)
SUN: SPARCstation 2 (toosy), Ultra 60 (<noname>), Blade 2000 (betsy)
Re: Forum with Netscape 3 ?
Unread postby Raion-Fox » Sun Jun 18, 2017 8:13 pm
Netscape 4 works fine.
You could always look into some sort of proxy system.
thunderbird32
Unread postby thunderbird32 » Mon Jun 19, 2017 9:55 am
There is also a third option: You could try Tenox's web rendering proxy. It converts web pages to clickable image maps. Should work on most browsers. Though when I tried it on Netscape 1.0, I couldn't get any of the links to work (that might just be Netscape 1.0 though).
You can find it here: https://github.com/tenox7/wrp
Digital Personal Workstation 500au
HP Visualize C3700 (HP-UX 11.11)
IBM RS/6000 7011-250 (AIX 4.3.3) | IBM RS/6000 7044-170 (AIX 5.3)
Sun SPARCclassic (SunOS 4.1.4) | Sun Ultra 1 (Solaris 2.6)
escimo
Unread postby escimo » Mon Jun 19, 2017 11:02 am
Thanks. I will pick the best option for me, claro. ;-)
Unread postby vishnu » Sat Jun 24, 2017 10:45 pm
Does anyone have the Netscape 0.93 IRIX binary? I've got the Win16 version version of it around here somewhere, I think. Or at least I used to...
escimo
Unread postby escimo » Sun Jun 25, 2017 8:26 am
Have to take a look into the downloads once did. But it will be more like version 1.x. Version 0.x, not sure.
jimmer
Unread postby jimmer » Sun Jun 25, 2017 9:25 am
vishnu wrote:Does anyone have the Netscape 0.93 IRIX binary? I've got the Win16 version version of it around here somewhere, I think. Or at least I used to...
Google provideth: http://home.mcom.com/archives/
:Fuel: redbox 800Mhz 4Gb V12
Unread postby vishnu » Sun Jun 25, 2017 5:13 pm
Huh! I thought he wrestled the mcom.com URL away from AOL but according to whois AOL still owns it... :shock:
Return to “Nekochan Net”
