Forum bug (arrows in code tags break posts)
Y888099
Unread postby Y888099 » Mon May 08, 2017 2:44 am
Hakimoto
Do not double post.
The only difference between this post and the other, that I can see, is that this one here is unfinished.
You do have the possibility of editing posts, so why create a second new post instead?
Locking.
This forum has a bug: if you put arrows inside a [ code ] ... [ /code ] session, bad things happen!
In first place, post gets corrupted.
Hakimoto
Re: Forum bug
Unread postby Hakimoto » Mon May 08, 2017 2:51 am
What kind of "arrows" are you referring to? Please post an example outside of a code tag here, so we can investigate this further. Thanks.
Changed topic title to be more informative.
grace, elegance and style.
Y888099
Re: Forum bug
Unread postby Y888099 » Mon May 08, 2017 3:06 am
Hakimoto wrote:What kind of "arrows"
Ones used on UNIX's shell to redirect the stdout/stdin, usually also used to indicate if something is greater, or less than.
It seems this forum reacts in bad way, which is odd if we consider that code /code should consider the text as *text*.
I happen to have PHP3 forum, it doesn't happen on my pages.
May be an hidden BBCode? A problem with the PHP parser?
This was the point, in my previous message, where things went wrong.
Re: Forum bug (arrows in code tags break posts)
Unread postby josehill » Mon May 08, 2017 7:18 am
This looks okay on my system:
Memory <- <0x0 0x40000000> (64MB)
CPU clock-frequency <- 0xfe49a80 (267MHz)
CPU timebase-frequencv <- 0xfe49a80 (267MHz)
/plb/opb: clock-frequency <- 1fc9350 (33MHz)
Could it be a problem with the UTF encoding of what you are entering or perhaps an issue with your browser's encoding settings?
Y888099
Unread postby Y888099 » Mon May 08, 2017 7:53 am
Good questions ...
Tried exactly the same, here it destroyed the post :shock: :shock: :shock:
I got:
[ code ]
Memory
I am on Chrome Version 49.0.2623.112
Windows XP/32bit
tingo
Unread postby tingo » Mon May 08, 2017 4:51 pm
It could be because the forum software allows (some) html tags (you know, words in '<' and '>' brackets, I've seen that problem on other forums before.
Torfinn
Unread postby vishnu » Mon May 08, 2017 8:07 pm
Testing:
 This is a greater than arrow: > This is a less than arrow: <
So, works for me, using Linux & firefox 51.0.1 :mrgreen:
Dodoid
Unread postby Dodoid » Wed May 10, 2017 7:43 am
vishnu's worked above, but they were ><. I'm guessing it has to do with HTML, so I would try <>
<text>
< text >
<text></text>
<-text->
<- text ->
<- text -> <-/text->
Working OK here, Firefox ESR 45.9.0 on Linux (Qubes OS Debian AppVM).
and a small army of Image
Unread postby josehill » Wed May 10, 2017 9:07 am
Y888099 - what are you using to post to the forum? Firefox? Safari? Lynx? Edge? IE? Something else? What version? What character encoding are you using?
I repeat my suspicion that your posting mechanism is using a UTF encoding that the forum software is not expecting, since others have been able to enter your problematic strings without trouble.
Y888099
Unread postby Y888099 » Thu May 11, 2017 11:58 am
josehill wrote:what are you using to post to the forum?
Windows XP/32bit
josehill wrote:What character encoding are you using?
UTF-8
Y888099
Unread postby Y888099 » Thu May 11, 2017 12:05 pm
Firefox v52.1.0 is also affected :shock:
[code]
Memory
spiroyster
Unread postby spiroyster » Thu May 11, 2017 1:16 pm
LGTM
Win10 Firefox 53.0.2 32bit
CLICK HERE to find out what click bait is. You will not believe what you discover.
#NaN singles in your area are already making gazzilions by using this trick.
Cambridge Analytica approved!!
Unread postby Raion-Fox » Thu May 11, 2017 3:24 pm
PEBKAC is evident.
I am probably posting from yangxiaolong, HP Z230 with Xeon E3-1245v3, 16GB RAM, GeForce 750ti, and running Xen on NetBSD dom0 with FreeBSD and Windows 8.1 Embedded.
Unread postby josehill » Thu May 11, 2017 11:28 pm
I just fired up a VM running 32 bit XP SP3 and loaded Chrome Version 49.0.2623.112, and that is what I am posting this message from. As the code above demonstrates, I am not able to duplicate the problem.
Unread postby Raion-Fox » Thu May 11, 2017 11:48 pm
The only thing I can think of is if your locale is not set to english. On Windows that can cause codepage issues because Windows sucks at localization.
Return to “Nekochan Net”
