I agree with what you said about SCSI devices, but I still lean towards keeping it separated by platform. I think that the idea is that a device should be on the list only if it is confirmed to work on a particular machine. It reduces the (admittedly, for SCSI, unlikely) possibility of time wasted trying to get an incompatible device working after reading an ambiguous compatibility report.
We could always put a note in the individual articles that SCSI devices that are confirmed to work on one type of system are likely to work on contemporary systems.
In any case, the important thing is to get the content up on the wiki, so if folks don't agree with my suggestion, no problem -- wikify as you see fit!
recondas wrote:
As long as we're dealing with SGI hardware of roughly the same era <O2, Octane, O2k, Onyx2, IP35, attributing specific SCSI devices to individual hardware platforms might be a little too fine-grained <SCSI devices such as hard drives, DVDs, CD-ROMs, CDRWs, but *not* PCI SCSI controllers> . I've worked my way through pretty much all of those systems, and can't recall a SCSI device that worked on one but not the others. I might have just been lucky, but if not, it'd save quite a bit of wiki creation time.
If a specific device appears in only one or two of the forum aggregators, it would be simple enough to add a note mentioning "not yet tested on platform X".
