YUM for AIX
Shiunbird
YUM for AIX
Unread postby Shiunbird » Thu Apr 20, 2017 9:26 am
I was casually fooling around the Interwebs when somehow I ended up in the Linux Toolbox for AIX page and I noticed that it was refreshed (for the first time in years probably).
And... guess what? There's now YUM for AIX.
I'm sure that will eliminate 90% of my frustration operating AIX and could help a few of us here.
https://www.ibm.com/developerworks/comm ... 02751d30e2
https://www.ibm.com/developerworks/comm ... erview.pdf
https://www-03.ibm.com/systems/power/so ... alpha.html
http://www-03.ibm.com/systems/power/software/aix/linux/
Enjoy!
Re: YUM for AIX
Unread postby Raion-Fox » Thu Apr 20, 2017 9:40 am
Eew redhat tools. I'd rather have a good pkgsrc.
Shiunbird
Re: YUM for AIX
Unread postby Shiunbird » Fri Apr 21, 2017 1:42 am
It is definitely better than figuring out everything manually. I've had my share of conflicting packages and frustrating dependency hunts...
Re: YUM for AIX
Unread postby ClassicHasClass » Fri Apr 21, 2017 5:26 am
I just use rpm.
astouffer
Re: YUM for AIX
Unread postby astouffer » Fri Apr 21, 2017 4:36 pm
Finally. With rpm I had conflicts where X needed Y, so you try and install Y and it says it needs X... So the hell with it, force everything. You should have seen me trying to install ffmpeg. Nothing seems to compile cleanly with gcc either.
Shiunbird
Re: YUM for AIX
Unread postby Shiunbird » Mon Apr 24, 2017 1:27 am
astouffer wrote:Finally. With rpm I had conflicts where X needed Y, so you try and install Y and it says it needs X... So the hell with it, force everything. You should have seen me trying to install ffmpeg. Nothing seems to compile cleanly with gcc either.
Exactly the problems I've been having.
Compiling things on gcc never seem to go well, or I'm too stoopid.
What happens to me is... when I need to get things done with the machine I end up booting Linux, and once every few months I gather some energy, spend 3-4 days with AIX, get frustrated and give up. But now I think I will do a 7.1 clean install and try my luck again.
ibmfiles
Re: YUM for AIX
Unread postby ibmfiles » Sat Apr 29, 2017 5:48 pm
Shiunbird wrote:I was casually fooling around the Interwebs when somehow I ended up in the Linux Toolbox for AIX page and I noticed that it was refreshed (for the first time in years probably).
Enjoy!
Oh wow, now I can actually set up the ol' IntelliStation and try installing some stuff later. ASSUMING it'll work fine with AIX 5.3 (later versions are really appropriate for a PowerPC anyways).
Raion-Fox wrote:Eew redhat tools. I'd rather have a good pkgsrc.
IBM invests to redhat, and sends over code and stuff. So it's not a surprise they've got the "redhat" bias. Which I can't say I'm a fan of redhat (is anyone, really?)
The AIX running man probably has developed a hernia by the amount of times he has belly flopped on failed SMITs. IBM should just freaking develop something more for the OS... for instance like USB storage that doesn't have a chance of getting corrupted.
praetor242
Re: YUM for AIX
Unread postby praetor242 » Mon May 08, 2017 12:28 pm
AIX is my second favorite UNIXen after IRIX, but adding software to it is such a massive pain-in-the-ass. I co-manage a beefy ass POWER server with a buddy of mine, and we're eager to try it out.
:Octane2: - augustus - COMING SOON :D :D
Return to “IBM”
