Powering SCSI media device on Power5
Shiunbird
Unread postby Shiunbird » Sun Feb 26, 2017 6:57 am
Hi guys,
As you probably noticed, I've received Ultrium drive from Y888099 (and unfortunately broke the right lock latch from my front panel during the installation ARGH).
I chose to take the drive because it is in the list of officially supported accessories - so it should just work and it looks NEAT:
However, it seems I need a "whatever-proprietary-garbage-to-molex" adapter that I can't find on eBay. It must exist, but I don't know how it is called. If you watch the embedded video here, you see the adapter hanging there: https://www.ibm.com/support/knowledgece ... imedia.htm
And here is how it looks like in more detail:
Any ideas?
Thanks as always!
Re: Powering SCSI media device on Power5
Unread postby robespierre » Sun Feb 26, 2017 8:42 am
So the drive isn't connected via its SCA2 port? That would provide power as well as data.
The black header looks like Molex BMI, but you need to know the pinout
astouffer
Unread postby astouffer » Sun Feb 26, 2017 12:01 pm
Can you get at this assembly while its installed? I would just measure the voltages in circuit. Two of those pins are likely connected together as ground so go from there. The drive has the normal PC style power connector so we know its pinout.
Shiunbird
Unread postby Shiunbird » Sun Feb 26, 2017 12:51 pm
robespierre wrote:So the drive isn't connected via its SCA2 port? That would provide power as well as data.
Not as I understand from the IBM page I linked to my original post. There's even room to get the SCSI cable around there, and something that clearly looks like a molex adapter. I would love a second opinion on the info from IBM.
astouffer wrote:Can you get at this assembly while its installed? I would just measure the voltages in circuit. Two of those pins are likely connected together as ground so go from there. The drive has the normal PC style power connector so we know its pinout.
Maybe. The angles and spaces are really tight once the whole thing is assembled. The external media bay is connected to the system via a connector on the motherboard, not via any cable, so I can't leave it hanging outside and power it on.
Y888099 sent me this picture from a HP machine, and it looks like the same thing. I just wish I knew how this is called to look for it.
Y888099
Unread postby Y888099 » Sun Feb 26, 2017 1:43 pm
I believe it's a molex cable made with standard connectors.
So, you can order those connectors and try to build the cable.
I wonder if the pinout of my cable works for your setup.
The picture I sent you comes from HP-PA model C3600.
astouffer
Unread postby astouffer » Sun Feb 26, 2017 3:50 pm
An old ATX power supply should have both these connectors. Fire up the soldering iron :)
Shiunbird
Unread postby Shiunbird » Sun Feb 26, 2017 11:54 pm
http://www.ebay.com/itm/97H5354-IBM-i5- ... SwVFlUChmG
Does it look like it?
It would be cheaper for me to buy one than buy an ATX power supply and a soldering iron. My soldering iron is 10000km from me. :(
Edit:
I found the small slim SCSI cable + power cable from the US, but that's too much money: http://www.ebay.com/itm/IBM-4263-4278-3 ... Sw3KFWcuUt
Found on eBay for 8 GBP from the UK only the power cable part number 97P5354 and took that one instead. There should be enough space to squeeze a full-length SCSI cable behind the media drive bay.
So in a week or two I'll have it running, thanks guys!
Y888099
Unread postby Y888099 » Mon Feb 27, 2017 3:42 am
Shiunbird wrote:Does it look like it?
No.
The molex 12-gnd-gnd-5 (which goes to feed HD/CD/etc) is ok.
The squared connector (which goes to the motherboard) is bigger than what you need.
Shiunbird
Unread postby Shiunbird » Wed Mar 08, 2017 11:35 am
She lives!
IBM PN 97P5354 molex cable did the trick - the one I got from eBay days ago.
Short enough to fit in the media bay without blocking the connectors, and it ties around the SCSI cable Y888099 sent over nicely.
I'm just running my first test backups here on AIX 7.1.
I'll now start writing the scripts that will take the data from my FreeNAS box, back it up and eject the tape so I can swap them as I need. I will also figure out the way to automatically power the IntelliStation up, and turn it off after the backups are done.
If any of you have tips or best practices on dealing with tape, let me know. I'm just getting started.
Thanks for all the help, and thanks to Y888099 for the drive. You all rock!
Unread postby uunix » Wed Mar 08, 2017 12:02 pm
Nice one Shiunbird , me thinks I will also purchase said molex cable.
Y888099
Unread postby Y888099 » Wed Mar 08, 2017 12:22 pm
Shiunbird wrote:Thanks for all the help, and thanks to Y888099 for the drive
Glad to hear it works ^_^
Your money invested into DVD-RAMs, and I am happy, too!
p.s. your POWER5 machines looks strange, but beautiful!
Shiunbird
Unread postby Shiunbird » Thu Mar 09, 2017 1:00 am
Y888099 wrote:p.s. your POWER5 machines looks strange, but beautiful!
It is gorgeous.
And I got it new in the box for 300 EUR from a company that went bankrupt in the Netherlands and had them in stock.
(yes, and 300 EUR for shipping 50kg, plus bribing three friends with beers to carry it four floors upstairs)
So yes, we are all happy. =)
Return to “IBM”
