Xlc compiler demo install
astouffer
Unread postby astouffer » Sat Feb 04, 2017 7:48 pm
I'm trying to install the xlc 13.1.3 compiler demo on my AIX 7.1 box but its failing over a pre requisite package.
  MISSING REQUISITES:  The following filesets are required by one or more
  of the selected filesets listed above.  They are not currently installed
  and could not be found on the installation media.
    bos.adt.libm 6.1.2.1                      # Fileset Update
The package bos.adt.libm is part of bos.rte.install.7.1.4.30. I downloaded and installed this package but still no go for xlc. It looks like the right packages are installed. The version listed above isn't even for my version of AIX.
# lslpp -l|grep -i bos.adt
  bos.adt.base              7.1.4.30  COMMITTED  Base Application Development
  bos.adt.include           7.1.4.30  COMMITTED  Base Application Development
  bos.adt.lib               7.1.2.15  COMMITTED  Base Application Development
Any ideas?
TruHobbyist
Re: Xlc compiler demo install
Unread postby TruHobbyist » Sun Feb 05, 2017 1:50 am
Hi,
has been a long time since I installed xlC on AIX the last time so just a few thoughts:
1. There is support for at least AIX 6.1 and AIX 7.1 according to:
http://www-969.ibm.com/software/reports ... forms=AIX#!
Maybe there are different releases of the compiler package for each OS Version?
2. Maybe a missing configuration option/flag is missing when running the installation?
Both cases would explain the V.R.M.F mismatch.
Regards,
Tru
Unread postby uunix » Sun Feb 05, 2017 2:13 am
astouffer wrote:I'm trying to install the xlc 13.1.3 compiler demo on my AIX 7.1 box but its failing over a pre requisite package.
Any ideas?
Checking the original AIX install CD I see:
  bos.adt.lib                7.1.0.0    C     F    Base Application Development
                                                   Libraries
  bos.adt.libm               7.1.0.0    C     F    Base Application Development
                                                   Math Library
  bos.adt.libmio             7.1.0.0    C     F    Modular IO Library
bos.adt                                                            ALL
 @ 7.1.0.0  Base Application Development Debuggers
 @ 7.1.0.0  Base Application Development Graphics Include Files
 @ 7.1.0.1  Base Application Development Include Files
 @ 7.1.0.0  Base Application Development Libraries
 @ 7.1.0.0  Base Application Development Math Library
 @ 7.1.0.0  Base Application Development Toolkit
 @ 7.1.0.0  Base Application Development Toolkit Data
 @ 7.1.0.0  Base Application Development Utilities - lex and yacc
 @ 7.1.0.0  Base Operating System Samples
 @ 7.1.0.1  Base Profiling Support
 @ 7.1.0.0  Modular IO Library
 @ 7.1.0.0  Printer Support Development Toolkit
 @ 7.1.0.0  SCCS Application Development Toolkit
 @ 7.1.0.1  System Calls Application Development Toolkit
 @ 7.1.0.0  Tool to Create installp Packages
bos.adt is located on Disk 1 of the AIX install disk.
Looking at what is installed (post xlC install)
My AIX install was a fresh install some years ago, as opposed to updating from 5 or 6, unsure if this makes any difference.
Hope this helps in some way.
[Edit]
Unsure if this is helpful, but my installed xlC is 13.1.0.0
  xlCcmp.13.1.0             13.1.0.0    C     F    XL C++ compiler
  xlCcmp.13.1.0.bundle      13.1.0.0    C     F    XL C++ media defined bundles
astouffer
Unread postby astouffer » Sun Feb 05, 2017 1:52 pm
Just wanted to say I installed the bos.adt package from disk 1 and xlc installed just fine. Thanks everyone.
Return to “IBM”
