Warp 3 to Warp 3 Connect
pentium
Unread postby pentium » Fri Jan 15, 2016 10:18 am
I've realized that I installed the basic blue spine version of Warp 3 onto my machine which doesn't include network enhancements. I have a copy of Warp 3 Connect but should I be upgrading by installing over the existing install or should I be formatting the partition and starting over?
kjaer
Re: Warp 3 to Warp 3 Connect
Unread postby kjaer » Fri Jan 15, 2016 12:24 pm
You should be able to just install MPTN &c. off the Connect disc. IIRC the Connect install does a totally normal OS/2 install, then starts a second installer to apply the Connect code. Connect is just a bundle of regular OS/2 plus a couple extra products which could also be ordered separately and applied to a non-Connect OS/2.
pentium
Unread postby pentium » Fri Jan 15, 2016 4:21 pm
Oh it's a separate installer. Awesome. I can try that.
Return to “IBM”
