Breaking in to an inherited AIX installation
aperezbios
Unread postby aperezbios » Fri Jun 19, 2015 10:58 am
As mentioned in another thread, I picked up an IBM RS/6000 7043-140, a 266MHz based 604e, and it came with an install of AIX 4.2 on a hellaciously-loud 4GB SCSI-II drive. I'd like to know if there's any equivalent in AIX-land to what I would do under Linux to recover root access to a machine, eg interrupt boot loader, add "single init=/bin/sh" to the bootargs, and then modify /etc/password and/or shadow.
Suggestions?
Re: Breaking in to an inherited AIX installation
Unread postby uunix » Fri Jun 19, 2015 11:34 am
iirc even booting into single user requires the root password.
Do you have the media disks?
nyef
Unread postby nyef » Fri Jun 19, 2015 11:58 am
Crazy question, but... Can you mount the disk in another machine and hack the password file that way?
Unread postby Trippynet » Fri Jun 19, 2015 12:38 pm
Yes.
Full instructions are in the Wiki.
Unread postby foetz » Fri Jun 19, 2015 12:45 pm
Trippynet wrote:Yes.
this is about irix, not aix
Unread postby uunix » Fri Jun 19, 2015 1:35 pm
Same would apply if you have another AIX box able to take said drive. I don't think shadow password malarkey was too strong in 4.x ???
Unread postby foetz » Fri Jun 19, 2015 2:16 pm
sure, the general concept goes for all. usually comes down to either booting with the os cd or putting the disk into another machine
Unread postby ClassicHasClass » Fri Jun 19, 2015 3:29 pm
There are a couple of local attacks you can mount, but you need to have *a* login (I broke into one of my old systems this way when I forgot what the root password was). I believe there are some CDE attacks you can try too, but since you have a real IBM machine, better just to get an AIX disc. You'll need it sooner or later anyway.
Unread postby Trippynet » Sat Jun 20, 2015 5:29 am
foetz wrote:this is about irix, not aix
Whoops, so it is. My bad :(
Return to “IBM”
