Intellistation 265 - Got it up and running - First impressions
Unread postby Raion-Fox » Sat Mar 07, 2015 9:33 pm
So I finally made time and tested the Intellistation 265.
First impressions:
The system I have is in decent shape, not perfect though as the front door is broken off. No matter, got it for $125 so it was a decent deal overall and I intend to drive it into the ground.
Has a copy of AIX 5.3 installed, so I booted into that. I was pleasantly surprised at smit, the management tool. I don't usually care for menu based config, but they give a surprising degree of flexibility. Already impressed! Added a user and started X. Well they didn't install CDE and I don't have the orginal CDs. Checked RPM for a compiler... nada. So I'm going to be busy obtaining an AIX 5.3 copy to install the missing pieces.
System is overall pretty quiet, but its obnoxious that I have to plug in two PSUs... Other than that it is quiet while running and not running. Heavy as a motherfucker, though, the thing clocks in at 82 lbs.
Plans for the system currently are to mess around and learn AIX. Once I learn AIX comfortably I'm going to try getting FreeBSD running on it and using it as a ZFS/SAS host controller. It actually only should consume a max of 480W according to the PSU ratings so not bad at all.
Re: Intellistation 265 - Got it up and running - First impressions
Unread postby uunix » Sun Mar 08, 2015 3:47 am
I've got a 285, really nice machine, but I haven't really got round to doing anything with it yet, I plan to run PostgreSQL on it. The only thing I've done, is put AIX 7 on it.
And yes, my system is so quiet I have to check the green light on the front to see if I've left it on.
One of the things I didn't learn quick enough was the 'on the fly' disk repartitioning. Had I known about it, I possible wouldn't have stayed at AIX 5.whatever.
Unread postby ClassicHasClass » Sun Mar 08, 2015 9:29 am
How is the 285 cooled?
AIX's "soft" partitions are part of what makes JFS great.
Unread postby uunix » Sun Mar 08, 2015 11:05 am
Without pulling the side off, just some big orange fans I think. Nothing special.
Interesting you ask that, I wonder if anyone has water cooled their Octane?
Unread postby ClassicHasClass » Sun Mar 08, 2015 1:25 pm
Well, I guess compared to the Quad, the POWER5+ in the 285 is clocked slower, and I imagine there were power utilization improvements between generations (though both the POWER5+ and the 970MP are 90nm).
Unread postby Raion-Fox » Sun Mar 08, 2015 1:38 pm
uunix wrote:Without pulling the side off, just some big orange fans I think. Nothing special.
Watercooling is a ripoff, its louder and if you have a good heatsink, less efficient.
Unread postby Raion-Fox » Mon Mar 16, 2015 9:49 am
System is now reloaded with a full AIX install, unfortunately I can't find a copy of the AIX cc, so I will deal with GCC... oh how I loathe it so. Oh well
Unread postby ClassicHasClass » Mon Mar 16, 2015 11:16 am
xlc is licensed anyway. Get used to gcc. xlc does generate better code in some situations, but IBM has contributed quite a bit to gcc, and remember that gcc was part of the Apple PowerPC toolchain as well.
Return to “IBM”
