Serial Out cu
Serial Out cu
Unread postby uunix » Fri Jan 23, 2015 3:56 pm
Evening folks.
I want to connect to [something] from Power5 911 285 running AIX 7.1 that has no HMC.
Serial cable is connected to Port1 (as identified on back - so Port0?)
So, in /etc/uucp/devices I have added the following line:
Direct tty0 - 9600 direct
cu -l /dev/tty0 fails NO DEVICES AVAILABLE (plus lots of other combinations.. tty1, vty0..)
So a few things are throwing me:
1/ Virtual ports vty0 etc
2/ I read that the ports are hardcoded for 19200 [????]
3/ Do I have to remove the device first via smit?
The device I'm connecting to has standard type settings 9600 8 1 etc..
Many thanks in advance.
Re: Serial Out cu
Unread postby ClassicHasClass » Fri Jan 23, 2015 9:41 pm
Don't use /dev/vty0; those are the ASMI-managed serial ports. It will work with getty as a serial console but it doesn't work as a general purpose serial port. For my AIX POWER6, I installed a "2-Port Asynchronous EIA-232 PCI Adapter" (FC 5723). These are very easy to find used; mine was $25. The card supports the smit PCI Hot Swap Manager assuming your hardware does.
Once installed, detected and configured, you should now have /dev/tty0 and /dev/tty1. In /etc/uucp/Devices, I have
Direct tty0 - 2400 direct
Direct tty0 - 4800 direct
Direct tty0 - 14400 direct
Direct tty0 - 19200 direct
Direct tty0 - 38400 direct
Direct tty0 - 57600 direct
Direct tty0 - 115200 direct
And the command line to talk to it would be
/usr/bin/cu -m -l/dev/tty0 -s115200
Re: Serial Out cu
Unread postby foetz » Fri Jan 23, 2015 10:18 pm
so the ibm boxes don't come with even one proper serial port by default? :shock:
Re: Serial Out cu
Unread postby ClassicHasClass » Sat Jan 24, 2015 8:41 am
Nope. Like I say, the VTYs suffice as serial consoles, but they won't work for, say, modems. That was the problem I had connecting my POWER6 to my GSM terminal.
Re: Serial Out cu
Unread postby foetz » Sat Jan 24, 2015 9:04 pm
ClassicHasClass wrote:they won't work for, say, modems
yeah what i meant, no proper ports then :P
Return to “IBM”
