How format as/400 scsi disk for use not with as/400?
SunForSun
Unread postby SunForSun » Sat Jul 20, 2013 5:09 pm
Hi again! I have one Hitachi Ultrastar ( model: IC35L036UCDY10-0, p/n: 08K0294, 35Gb size), my SGI Octane show as :
octane4 5# fx -x
fx version 6.5, Jan 7, 2004
fx: "device-name" = (dksc)
fx: ctlr# = (0)
fx: drive# = (1) 2
fx: lun# = (0)
...opening dksc(0,2,0)
...drive selftest...OK
Scsi drive type == IBMAS400DDYS36M S27E
But, cannot label :
label info has changed for disk dksc(0,2,0). write out changes? (yes) yes
fx/exit: Error: Invalid argument: on write at block 2 for 1 block
retry #2
retry #3
retry #4
fx/exit: Warning: can't write sgilabel
Cannot mkfs, fsck :
octane4 14# mkfs /dev/rdsk/dks0d2s0
bdstrat: writeb failed: I/O error
meta-data=/dev/rdsk/dks0d2s0 isize=256 agcount=33, agsize=262144 blks
data = bsize=4096 blocks=8554112, imaxpct=25
= sunit=0 swidth=0 blks, unwritten=1
naming =version 2 bsize=4096 mixed-case=Y
log =internal log bsize=4096 blocks=1200
realtime =none extsz=65536 blocks=0, rtextents=0
bdstrat: readb failed: I/O error
filesystem failed to initialize
octane4 15# fsck -y /dev/rdsk/dks0d2s0
fsck: I/O error
CANNOT BLOCK READ: BLK 1
CONTINUE? yes
Primary superblock inaccessible or invalid. Trying secondary.
fsck: I/O error
CANNOT BLOCK READ: BLK 68432895
CONTINUE? yes
No filesystem on /dev/rdsk/dks0d2s0
Is possible convert/format for efs filesystem ?
SunForSun
Re: How format as/400 scsi disk for use not with as/400?
Unread postby SunForSun » Sat Jul 20, 2013 5:29 pm
Any idea which utilites or progamm there are be on IRIX ( like i scsitool, or some low-level format )?
Unread postby hamei » Sat Jul 20, 2013 7:07 pm
SunForSun wrote: ... or some low-level format ?
That subject used to cause endless debates in the sgi newsgroups. If you want to cut to the chase just grab any old adaptec card (back to a 2940), stick it in a peecee, and do a low-level from the BIOS. That's the quickest, cheapest, simplest, most foolproof way to accomplish this task.
Unread postby robespierre » Sun Jul 21, 2013 1:19 am
fx> label/set/g
change data bytes/sec to 512, let other parameters default
fx> d/format
fx/debug/format: Drive parameters to use in formatting = (current)
exit and re-enter fx, and do label/create as normal, label/sync
SunForSun
Unread postby SunForSun » Sun Jul 21, 2013 2:41 am
robespierre thanks!
octane4 1# prtvtoc /dev/rdsk/dks0d2s0
* /dev/rdsk/dks0d2s0 (bootfile "/unix")
* 512 bytes/sector
Partition Type Fs Start: sec Size: sec Mount Directory
0 xfs 266240 68427776
1 raw 4096 262144
8 volhdr 0 4096
10 volume 0 68694016
octane4 2# mkfs /dev/rdsk/dks0d2s0
data = bsize=4096 blocks=8553472, imaxpct=25
uridium
Unread postby uridium » Sun Feb 09, 2014 3:06 am
AS/400's enjoy 520byte sectors. If I understand it correctly, you've got 512bytes for data, and 8 bytes for virtual memory extension tagging. They don't have "swap" per-say, merely things may exist and run from Primary Storage or Secondary storage.
520 byte sectors ought make most systems barf. :) Low leveling it as was suggested ought slip it the bullet.
Al Boyanich
Return to “IBM”
