IBM Mainframe Emulation on IRIX..
PymbleSoftware
Unread postby PymbleSoftware » Thu Feb 18, 2010 5:24 am
I threw 12 CPUs and gcc version 3.4.6 at the hercules IBM Mainframe emulator with a gmake -j14..
The original source is from:
http://www.hercules-390.org/
Took about an hour to hack around in the code and 3 minutes to build on the 12 CPU Origin 300 and about 19 and a half minutes of CPU time...
real    3m5.439s
user    19m36.003s
sys     1m6.835s
My build is attached to this thread... I don't have time to do a MIPS Pro build..
I did start messing with MIPS Pro on the dual Octane and ran out of time..
I did some minor hacking around with the code to get it to build...
I took all the functionality of SCSI tape drives out in order to get it to build..
Do not hook up tape drives and expect to be able to process mainframe tapes..
These question are answered in the FAQ ( http://www.hercules-390.org/hercfaq.html ):
2.04 Where can I obtain OS/360 ?
2.05 Where can I obtain MVS ?
2.06 Where can I obtain VM/370 ?
2.07 Where can I obtain DOS/VS ?
2.08 Where can I obtain Linux/390 ?
Enjoy.
hercules-3.06-built.tar.gz
(8.06 MiB) Downloaded 98 times
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Re: IBM Mainframe Emulation on IRIX..
Unread postby hamei » Thu Feb 18, 2010 8:04 am
PymbleSoftware wrote:... hercules IBM Mainframe emulator
That thing looks pretty cool, Pym. Thank you.
alix
Unread postby alix » Thu Feb 25, 2010 6:16 am
Very nice work, Thanks a lot! Regards, Alex
Forget UNIX - it will be gone in 5 years. [Tom Jermoluk, SGI]
geezer
Unread postby geezer » Thu Feb 25, 2010 6:48 am
Thanks! What an amazing piece of software...
:O3000: :O2000R: :Onyx: :O2000: :Indigo: :O2: :Indigo2IMP: :Fuel: :1600SW: :1600SW:
Shoot the wall, leave the birds alone.
necron2600
Unread postby necron2600 » Mon Aug 29, 2016 6:43 pm
Anyone have a copy of this? Seems to have gone missing?
"The selected attachment does not exist anymore."
If anyone does have a copy.. can they repost with it here?
Thanks
Krokodil
Unread postby Krokodil » Mon Aug 29, 2016 7:13 pm
Funny. A few weeks ago, I was wondering if someone made a Hercules port for IRIX.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
Unread postby dexter1 » Tue Aug 30, 2016 2:57 am
Did you try PM'ing PymbleSoftware? He is still active...
Plus the code is now version 3.07, so maybe a new version is possible
necron2600
Unread postby necron2600 » Wed Jan 04, 2017 5:04 pm
Compiled hercules 3.07 with GCC 4.7
Not much had to be modified
I did try MIPSPro first.. it started to get hairy.
# Environment
export CC=gcc
export CXX=g++
export CXXFLAGS="-O3 -mabi=n32 -I/usr/nekoware/include -I/usr/include"
export CPPFLAGS="-O3 -mabi=n32 -I/usr/nekoware/include -I/usr/include"
export PATH="/usr/nekoware/bin:$PATH"
export MANPATH="/usr/nekoware/man:$MANPATH"
export CFLAGS="-O3 -mabi=n32 -I/usr/nekoware/include -I/usr/include"
export LDFLAGS="-L/usr/nekoware/lib -L/usr/lib32"
export LD_LIBRARY_PATH="/usr/nekoware/lib:/usr/lib32"
export PATH=/usr/nekoware/gcc-4.7/bin:$PATH
./configure --enable-getoptwrapper
Comment out.. or better yet add a !defined for SGI somehow.. I got lazy and commented out:
hercifc.h
//#if !defined(__APPLE__) && !defined(__FreeBSD__) && !defined(__SOLARIS__)
// struct rtentry rtentry;
//#endif
Add:
#include "db.h"
to top of:
crypto/dyncrypt.c
crypto/sha1.c
crypto/sha256.c
then it compiles with no errors.
I only tested it by running it, then stopping it. I have no clue (yet) if it functions right. Just got happy and decided to post it first.. who needs testing right? ;)
hercules-3.07-gcc-compiled-irix-mips4.tar.gz
(2.45 MiB) Downloaded 23 times
necron2600
Unread postby necron2600 » Wed Jan 04, 2017 5:05 pm
Oh.. it installs in /usr/local. the tarball is a tar of usr (I ran gmake install DESTDIR=/tmp/somewhere to package it up in a tarball)
necron2600
Unread postby necron2600 » Thu Jan 05, 2017 2:40 pm
curses based 3270 term emulator compiled with GCC for mips4..
c3270-3.3.tar.gz
(291.13 KiB) Downloaded 22 times
pentium
Unread postby pentium » Thu Jan 05, 2017 7:34 pm
Nice! Now I can run Hercules on the O2K and have the emulator running from the O2.
Return to “IBM”
