OS/2 support
pentium
OS/2 support
Unread postby pentium » Fri Dec 29, 2006 11:14 am
For a while I have been waiting to find a system to install my copy of IBM's OS/2 2.1 Operating system on. One thing is certain it needs to be AT and there can't be any new hardware. This limits me down to older brand systems like packard bell and compaq, two systems which seem to be really popular in my parts. I also looked into going genuine and getting a PS/2 system but they strangely dissapeared form here in the last two years. My attemp at running it on my laptop shows that it has a very limited selection of drivers and all cd support needs to be SCSI.
In your opinion, would you recommend I just search for an ibm to use or use a clone?
zizban
Unread postby zizban » Fri Dec 29, 2006 2:09 pm
One word: Ebay
Get At least Warp 4. You'd need something like a 486 machine to run 2.1. Warp 4 is faster and supports much more hardware.
pentium
Unread postby pentium » Fri Dec 29, 2006 10:16 pm
Erm, I kinda wanted an older system to play with.
Ebay it is though.
zizban
Unread postby zizban » Sat Dec 30, 2006 8:30 am
The novelty wear off factory of OS/2 2 is pretty fast--it was great at the time, cutting edge but but by today's standards it really is kinda cruddy and you'll be frustrated pretty fast.
pentium
Unread postby pentium » Sat Dec 30, 2006 10:12 am
You got a point there.
That and it's hard to find OS/2 software.
zizban
Unread postby zizban » Sat Dec 30, 2006 10:15 am
Its easy to find OS/2 software; its hard to find software that runs on OS/2 2
Unread postby hamei » Sat Dec 30, 2006 12:07 pm
zizban wrote:Its easy to find OS/2 software; its hard to find software that runs on OS/2 2
http://hobbes.nmsu.edu
seven and a half gigabytes (loosely measured)
good information :
http://pages.prodigy.net/michaln/history
pentium
Unread postby pentium » Sat Dec 30, 2006 12:09 pm
:roll:
Leave it to hamei.
OS/2
Unread postby SAQ » Sat Dec 30, 2006 12:12 pm
Get all the service packs you think you'll need now, since OS/2 support is being discontinued and I'm not sure if this means IBM will pull all the OS/2 stuff or not.
pentium
Unread postby pentium » Sat Dec 30, 2006 12:13 pm
I thought the pulled the plug on OS/2 support years ago?
Unread postby hamei » Sat Dec 30, 2006 12:25 pm
pentium wrote:I thought the pulled the plug on OS/2 support years ago?
That's what the toady press would like you to believe :) No worry about fixpacks, they're on Hobbes and elsewhere. Plus OS/2 isn't really dead, it's being sold by Serenity as eComStation. Not sure what the inner workings are there but the serene principal is a long-time IBM-er.
If you want something really rare, try for this :
http://pages.prodigy.net/michaln/histor ... index.html
pentium
Unread postby pentium » Sat Dec 30, 2006 12:54 pm
*whistles*
That's a gem.
I just wanted OS/2 so I can kill three birds with one stone:
-one computer
-run DOS
-Run windows 3.1 (included in my copy)
-run OS/2
This is also the only old operating system I have where hardware that's listed as compatible I actualy own so I don't have to look for the drivers.
zizban
Unread postby zizban » Sat Dec 30, 2006 2:01 pm
I know about Hobbes :)
What I was saying was that apps that run on an OS/2 that old are hard to find.
As best I understand it was Serenity took over development of Warp 4.52 and renamed it eComstation. While Serenity is the primary developer, they also have the help of IBM and a few others.
Also I as I understand it the high cost of eComstation is because IBM charges Serenity a hefty royalty for each copy sold. You know Serenity would love to sell eComstation for $99 if they could.
Unread postby hamei » Sat Dec 30, 2006 9:58 pm
zizban wrote:What I was saying was that apps that run on an OS/2 that old are hard to find.
Hmm. 2.1 isn't actually that old. In fact, you can use many drivers from Warp in v 2.1. I would bet that almost all current OS/2 applications would run in 2.1 - tho going to 2.11 would be preferable. Same system, just some fixes.
Yup :-) And the reason IBM prices are high is that IBM gets to pay Microsoft a royalty on most copies of OS/2. Hard to believe just how screwed up IBM was in the eighties and early nineties. It'll be interesting to see if SGI can pull out of their dive the way IBM managed to. Doesn't look like it so far tho :P
Serenity is now pushing virtual machines. IBM really loves that technology, and they're good at it.
http://serenityvirtual.com/index.php
Unread postby hamei » Sat Dec 30, 2006 10:46 pm
http://www.ubersoft.net/d/20050718.html
http://www.ubersoft.net/d/20050721.html
Irix == OS/2 ?
(Definitely worth a look here, pentiium - some very interesting history
http://pages.prodigy.net/michaln/histor ... index.html )
Return to “IBM”
