HP-UX 11.00 Packages
Unread postby foetz » Thu Feb 22, 2018 4:22 pm
a humble selection but since packages for 11.00 are rather rare i figured i could just as well share my small archive.
all are built on 11.00 with the native compilers unless noted otherwise. 32bit pa-risc 1.1 som files, optimized as hell, reasonable feature selection ... the usual :P
  • apr_0912.depot.bz2
  • aprutil_0912.depot.bz2
  • bzip2_64.gz
  • curl_712.depot.bz2
  • diffutils_32.depot.bz2
  • gimp_125.tar.bz2
  • glib_1210.depot.bz2
  • gtk_1210.depot.bz2
  • libintl.sl.1.bz2
  • libjpeg_9c.depot.bz2
  • libpng_1212.depot.bz2
  • nedit_56-RAC.tar.bz2
  • ntp_411.depot.bz2
  • stunnel_544.tar.bz2
  • svn_155.depot.bz2
  • sylpheed_106.tar.bz2
  • tcl_805.depot.bz2
  • tcsh.bz2
  • tiff_409.depot.bz2
  • tk_805.depot.bz2
  • vim_80586.depot.bz2
  • wget.bz2
  • xv.bz2
  • zlib_1211.depot.bz2
- tar.bz2 archives expect to reside in /usr/local unless noted otherwise.
- the depots have no dependencies included so use common sense for what you need.
- the single files are just executables that should go to /usr/local/bin. sort of a basic set to get you started.
- the libintl.sl.1 is the only part of gettext that's needed for hp's mozilla. just throw it into a folder of your choice that's part of your SHLIB_PATH.
http://www.nekochan.net/downloads/index ... tz%2Fhpux/
append the package name since there's no listing
Return to “HP/DEC/Compaq”
