Hpux 11.11 shlib_path
khalidschofield
Unread postby khalidschofield » Tue Jan 17, 2017 1:28 am
Hi
I'm fairly new to hpux (been years since I used it) . I've installed via depothelper a lot of the packages from http://hpux.connect.org.uk but hardly anything works due to the shared library path and some complain about library version conflicts. I've tried setting the library path in /etc/SHLIB_PATH but this has no effect. I've also tried to copy /etc/csh.login to my home/.cshrc with no effect. I've tried using Bach and for some reason the shell isn't reading the configs either /etc/profile or .profile. Any tips what I'm doing wrong?
Re-install with OpenBSD :)
khalidschofield
Re: Hpux 11.11 shlib_path
Unread postby khalidschofield » Thu Jan 19, 2017 12:48 pm
After installing apps from http://hpux.connect.org.uk/ it has been hell. I've manually had to set /etc/SHLIB_PATH to add every single Sub directory of /use/local/lib/ to the LD_LIBRARY_PATH and also SHLIB_PATH tedious but mostly worked. The fonts for FileZilla don't show and I get a lot of very odd colours. Assume another library or took kit issue maybe gtk. There really isn't much hpux info online. Tonnes of irix info but hpux doesn't seem to have hobby forums with reasonable documentation.
kjaer
Unread postby kjaer » Thu Jan 19, 2017 3:10 pm
khalidschofield
Unread postby khalidschofield » Thu Jan 19, 2017 3:34 pm
not sure i understand the man page's relevance. For example
# fetchmail
fetchmail: WARNING: Running as root is discouraged.
/usr/lib/dld.sl: Unresolved symbol: getaddrinfo (code)  from fetchmail
Abort (core dumped)
# chatr +s enable fetchmail
chatr(error): dl_header_ext.size != sizeof(dl_header_ext). Please update your version of the chatr tool.
fetchmail:
   current values:
         shared executable
         shared library dynamic path search:
             SHLIB_PATH     enabled   second
             embedded path  enabled   first  /usr/local/lib
         shared library list:
             static    /usr/local/lib/libintl.sl
             static    /usr/local/lib/libiconv.sl
             dynamic   /usr/local/lib/libssl.sl
             dynamic   /usr/local/lib/libcrypto.sl
             dynamic   /usr/lib/libc.2
         shared library binding:
             deferred
         global hash table disabled
         plabel caching disabled
         global hash array size:1103
         global hash array nbuckets:3
         shared vtable support disabled
         static branch prediction disabled
         executable from stack: D (default)
         kernel assisted branch prediction enabled
         lazy swap allocation disabled
         text segment locking disabled
         data segment locking disabled
         third quadrant private data space disabled
         fourth quadrant private data space disabled
         data page size: D (default)
         instruction page size: D (default)
   new values:
         shared executable
             deferred
Unread postby ClassicHasClass » Thu Jan 19, 2017 4:59 pm
getaddrinfo couldn't be resolved?? That's a pretty bad sign. I don't remember exactly where that lives, but it should be either libresolv or libsocket. What do those look like?
khalidschofield
Unread postby khalidschofield » Sun Jan 29, 2017 2:53 am
I was wondering do I have all the HP-UX bundles installed that I need to run the gnu software on http://hpux.connect.org.uk
I still get errors such as this: fetchmail
Abort (core dumped)
# /opt/ignite/bin/print_manifest
System Information
    Your Hewlett-Packard computer has software installed and
    configured as follows.
    The system was created December 31, 1969, 19:41:29 EST.
    It was created with Ignite-UX revision C.7.9.260.
NOTE: You should retain this information for future reference.
System Hardware
    Model:              9000/785/C8000
    Main Memory:        12286 MB
    Graphics:           ATI Fire GL X1 color 0x0 48 planes
    Processors:         4
    Proccesor(0) Speed: 1100 MHz
    Proccesor(1) Speed: 1100 MHz
    Proccesor(2) Speed: 1100 MHz
    Proccesor(3) Speed: 1100 MHz
    OS mode:            64 bit
    LAN hardware ID:    0x00110A317A61
    Software ID:        Z56bb5389fb0d1eba
    Keyboard Language:  USB_PS2_DIN_UK_English
    Storage devices                  HW Path           Interface
    COMPAQ BF07288576 69464 Mb       0/2/1/0.5.0       SCSI Ultra320 A6961-60011
    HL-DT-STCD-RW GCE-8486B          0/3/2/0.1.0.0     IDE
    COMPAQ BF07285A36 69464 Mb       0/2/1/0.6.0       SCSI Ultra320 A6961-60011
    I/O Interfaces
    Class          H/W Path       Driver         Description
    ext_bus        0/2/1/0        mpt            SCSI Ultra320 A6961-60011
    ext_bus        0/2/1/1        mpt            SCSI Ultra320 A6961-60011
    usb            0/3/1/0        hcd            NEC USB Interface
    usb            0/3/1/1        hcd            NEC USB Interface
    usb            0/3/1/2        ehci           NEC USB Interface
    sideba         0/3/2/0        side_ba        CMD IDE controller
    ext_bus        0/3/2/0.0      side           IDE
    ext_bus        0/3/2/0.1      side           IDE
    lan            0/3/3/0        iether         HP  PCI 1000Base-T Built-in
    audio          0/3/5/0        audio          Plug-in PCI Audio
    graphics       0/4/0/0        gvid_core      AGP Display (10024e47)
    graphics       0/4/0/1        gvid_core      PCI Display (10024e67)
    ipmi           16             ipmi           IPMI Controller
    tty            17             asio0          Built-in RS232C
    tty            18             asio0          Built-in RS232C
Installed Software
    Your system was installed with HP-UX version B.11.11.
    Your system has the following software products installed and
    configured on the system disk drive(s).
    Product          Revision          Description
    B6848BA          1.4.gm.46.13      Ximian GNOME 1.4 GTK+ Libraries for HP-UX
    B9073BA          B.11.11.08.01.00.81HP-UX iCOD Instant Capacity (iCAP)
    BUNDLE11i        B.11.11.0306.1    Required Patch Bundle for HP-UX 11i, June 2003
    Base-VXVM        B.03.50.5         Base VERITAS Volume Manager Bundle 3.5 for HP-UX
    CDE-ChineseS     B.11.11.0412      Simplified Chinese CDE Environment
    CDE-ChineseT     B.11.11.0412      Traditional Chinese CDE Environment
    CDE-English      B.11.11.0412      English CDE Environment
    CDE-French       B.11.11.0412      French CDE Environment
    CDE-German       B.11.11.0412      German CDE Environment
    CDE-Italian      B.11.11.0412      Italian CDE Environment
    CDE-Japanese     B.11.11.0412      Japanese CDE Environment
    CDE-Korean       B.11.11.0412      Korean CDE Environment
    CDE-Spanish      B.11.11.0412      Spanish CDE Environment
    CDE-Swedish      B.11.11.0412      Swedish CDE Environment
    FDDI-00          B.11.11.02        PCI FDDI;Supptd HW=A3739A/A3739B;SW=J3626AA
    FEATURE11-11     B.11.11.0209.5    Feature Enablement Patches for HP-UX 11i, Sept 2002
    FIREFOX          1.5.0.00.02       Firefox for HP-UX
    FIREFOXsrc       1.5.0.00.02       Firefox Source distribution
    FibrChanl-00     B.11.11.13        PCI/HSC FibreChannel;Supptd HW=A6684A,A6685A,A5158A,A6795A
    FibrChanl-01     B.11.11.10        FibreChannel;HW=A6826A,A9782A,A9784A,AB378A/B,AB379A/B,AB465A,AD193A,AD194A
    GTK              2.6.8.00.01       GTK+ 2.6 The Gnome GUI Runtime  Toolkit
    GTKsrc           2.6.8.00.01       Gtk Source distribution
    GigEther-00      B.11.11.19        PCI/HSC GigEther;Supptd HW=A4926A/A4929A/A4924A/A4925A;SW=J1642AA
    GigEther-01      B.11.11.23        PCI/PCI-X GigEther;Supptd HW=A6794A/A6825A/A6847A/A9782A/A9784A/A7109A/AB465A
    HPUX11i-TCOE     B.11.11.0612      HP-UX Technical Computing OE Component
    HPUXBase64       B.11.11           HP-UX 64-bit Base OS
    HPUXBaseAux      B.11.11.0612      HP-UX Base OS Auxiliary
    HWEnable11i      B.11.11.0612.458  Hardware Enablement Patches for HP-UX 11i v1, December 2006
    IEther-00        B.11.11.13        PCI/PCI-X IEther;Supptd HW=A7011/A7012/AB352/AB290/AB545/AD193/AD194/AD331/AD332
    ISEEPlatform     A.03.95.500.41    ISEE Platform
    J4269AA          B.04.00.02        LDAP-UX Integration
    Java15JDK        1.5.0.04.00       Java 1.5 JDK for HP-UX
    Java15JDKadd     1.5.0.04.00       Java 1.5 JDK -AA addon for HP-UX
    Java15JRE        1.5.0.04.00       Java 1.5 JRE for HP-UX
    Java15JREadd     1.5.0.04.00       Java 1.5 JRE -AA addon for HP-UX
    MOZILLA          1.7.13.01.00      Mozilla for HP-UX
    MOZILLAsrc       1.7.13.01.00      Mozilla Source distribution
    NParCmds         A.01.03           Enhanced NPartition Commands
    OnlineDiag       B.11.11.18.05     HPUX 11.11 Support Tools Bundle, Dec 2006
    OpenSSL          A.00.09.07i.012   Secure Network Communications Protocol
    ParMgr           B.12.02.02.02     Partition Manager - HP-UX
    RAID-00          B.11.11.01        PCI RAID; Supptd HW=A5856A
    RAID-01          B.11.11.0609      RAID SA; Supptd HW=A7143A/A9890A/A9891A
    SysFaultMgmt     A.04.00.04.02     HPUX 11.11 System Fault Management
    SysMgmtWeb       A.2.2.5           HP-UX Web Based System Management User Interfaces
    T1456AA          1.4.2.11.00       Java2 1.4 SDK for HP-UX
    T1456AAaddon     1.4.2.11.00       Java2 1.4 SDK -AA addon for HP-UX
    T1457AA          1.4.2.11.00       Java2 1.4 RTE for HP-UX
    T1457AAaddon     1.4.2.11.00       Java2 1.4 RTE -AA addon for HP-UX
    T1458AA          1.4.2.11.00       Java2 1.4 Netscape Plugin for HP-UX
    T1471AA          A.04.30.006       HP-UX Secure Shell
    TBIRD            1.5.0.00.02       Thunderbird for HP-UX
    TBIRDsrc         1.5.0.00.02       Thunderbird Source distribution
    UtilProvider     A.01.04.02.00     HP-UX Utilization Provider
    WBEMSvcs         A.02.05           HP WBEM Services for HP-UX
    hpuxwsApache     A.2.0.58.00       HP-UX Apache-based Web Server
    hpuxwsTomcat     A.5.5.9.03        HP-UX Tomcat-based Servlet Engine
    hpuxwsWebmin     A.1.070.08        HP-UX Webmin-based Admin
    hpuxwsXml        A.2.00            HP-UX XML Web Server Tools
    nParProvider     B.12.01.07.01     nPartition Provider - HP-UX
    perl             D.5.8.8.B         5.8.8 Perl Programming Language
    scsiU320-00      B.11.11.0612.01   PCI-X SCSI U320; Supptd HW=A7173A/AB290A
    vParProvider     B.11.11.01.03     vPar Provider - HP-UX
    GConf            2.22.0            GConf
    ImageMagick      6.8.6.9           ImageMagick
    Mesa             7.4.4             Mesa
    ORBit2           2.14.19           ORBit2
    SDL              1.2.15            SDL
    aalib            1.4.0             aalib
    apr              1.5.0             apr
    apr_util         1.5.3             apr_util
    ascpu            1.9               ascpu
    atk              2.8.0             atk
    audiofile        0.2.7             audiofile
    babl             0.1.10            babl
    bash             4.3.033           bash
    bison            2.7.1             bison
    bzip2            1.0.6             bzip2
    cairo            1.12.16           cairo
    calc             1.01              calc
    catdoc           0.94.3            catdoc
    cftp             0.12              cftp
    chbg             1.5               chbg
    coreutils        8.22              coreutils
    cpio             2.11              cpio
    cups             1.7.1             cups
    curl             7.34.0            curl
    cyrus_sasl       2.1.26            cyrus_sasl
    db               6.0.20            db
    depothelper      2.00              depothelper
    di               4.34              di
    dillo            0.8.5             dillo
    editline         2.9               editline
    enchant          1.6.0             enchant
    esound           0.2.41            esound
    expat            2.1.0             expat
    fetchmail        6.3.26            fetchmail
    filezilla        3.0.4             filezilla
    findutils        4.4.2             findutils
    flex             2.5.37            flex
    fontconfig       2.11.0            fontconfig
    freetype         2.5.2             freetype
    fribidi2         0.19.2            fribidi2
    gcc              4.2.3             gcc
    gdbm             1.10              gdbm
    gdk_pixbuf       2.28.2            gdk_pixbuf
    gegl             0.2.0             gegl
    gettext          0.18.3.2          gettext
    gftp             2.0.19            gftp
    ghostscript      9.06.0            ghostscript
    gimp             2.8.10            gimp
    glib             1.2.10            glib
    glib2            2.34.3            glib2
    gliv             1.9.7             gliv
    gmp              5.0.5             gmp
    gnumeric         1.12.9            gnumeric
    gnupg            2.0.22            gnupg
    gnutls           3.2.9             gnutls
    goffice          0.10.9            goffice
    gqview           2.0.4             gqview
    grep             2.16              grep
    groff            1.22.2            groff
    gtk+             1.2.10            gtk+
    gtk+2            2.24.22           gtk+2
    gtk+3            3.6.4             gtk+3
    gtkglext         1.2.0             gtkglext
    gutenprint       5.2.9             gutenprint
    gzip             1.6               gzip
    harfbuzz         0.9.25            harfbuzz
    heimdal          1.5.2             heimdal
    imlib            1.9.15            imlib
    intltool         0.50.2            intltool
    jasper           1.900.1           jasper
    jbigkit          2.0               jbigkit
    jpeg             9.0.0             jpeg
    lame             3.99.5            lame
    lcms             1.19              lcms
    lcms2            2.5               lcms2
    ldns             1.6.16            ldns
    less             458               less
    lesstif          0.95.2            lesstif
    libIDL           0.8.14            libIDL
    libXft           2.3.1             libXft
    libXpm           3.5.11            libXpm
    libXrender       0.9.8             libXrender
    libart_lgpl      2.3.21            libart_lgpl
    libassuan        2.1.1             libassuan
    libcroco         0.6.8             libcroco
    libffi           3.0.13            libffi
    libgcc           4.2.3             libgcc
    libgcrypt        1.6.0             libgcrypt
    libglade         2.6.4             libglade
    libgpg_error     1.12              libgpg_error
    libgsf           1.14.29           libgsf
    libiconv         1.14              libiconv
    libidn           1.28              libidn
    libksba          1.2.0             libksba
    libpcap          1.5.3             libpcap
    libpng           1.6.8             libpng
    librsvg          2.40.1            librsvg
    libtasn1         3.4               libtasn1
    libtool          2.4.2             libtool
    libungif         4.1.4             libungif
    libunistring     0.9.3             libunistring
    libwmf           0.2.8.4           libwmf
    libxml2          2.9.1             libxml2
    lynx             2.8.7             lynx
    lzlib            1.5               lzlib
    lzma             4.32.7            lzma
    lzo              2.06              lzo
    m4               1.4.17            m4
    make             4.0               make
    md5              1.00              md5
    mpg123           1.17.0            mpg123
    mutt             1.5.21            mutt
    ncurses          5.9               ncurses
    neon             0.30.0            neon
    nettle           2.7.1             nettle
    nmap             4.76              nmap
    openldap         2.4.38            openldap
    openssl          1.0.2j            openssl
    p11_kit          0.20.1            p11_kit
    p7zip            9.20.1            p7zip
    pango            1.34.1            pango
    pangox           0.0.2             pangox
    pbzip2           1.1.8             pbzip2
    pcre             8.34              pcre
    pdftk            2.02              pdftk
    pdftohtml        0.39              pdftohtml
    perl             5.10.1            perl
    pigz             2.3.1             pigz
    pine             4.64              pine
    pinentry         0.8.3             pinentry
    pixman           0.32.4            pixman
    pkgconfig        0.28              pkgconfig
    plzip            0.9               plzip
    popt             1.16              popt
    procmail         3.22              procmail
    pth              2.0.7             pth
    python           2.7.6             python
    qpdf             3.0.2             qpdf
    readline         6.2.005           readline
    rsync            3.1.0             rsync
    screen           4.0.3             screen
    sed              4.2.2             sed
    sitecopy         0.16.6            sitecopy
    sqlite           3.8.2             sqlite
    subversion       1.8.5             subversion
    sylpheed         3.3.0             sylpheed
    t1lib            5.1.2             t1lib
    tcpdump          4.5.1             tcpdump
    tcsh             6.18.01           tcsh
    termcap          1.3.1             termcap
    tiff             4.0.3             tiff
    unbound          1.4.21            unbound
    unzip            6.0               unzip
    uudeview         0.5.20            uudeview
    vim              7.4               vim
    wget             1.15              wget
    which            2.20              which
    wxGTK            2.8.12            wxGTK
    xinvest          2.6.9             xinvest
    xpaint           2.7.0             xpaint
    xpdf             3.03              xpdf
    xterm            301               xterm
    xz               5.0.5             xz
    zip              3.0               zip
    zlib             1.2.8             zlib
LVM File System Configuration
    This system is configured with Logical Volume Manager (LVM) file systems.
    Refer to the File System layout section for information on the LVM layout.
JFS File System Configuration
    This system is configured with a Journaled File System (referred to
    as either JFS or VXFS).  Refer to the File System layout section for
    information on JFS/VXFS file systems.
Disk layout
    LVM disk                   Device file        HW Addr      size   vol. grp
    COMPAQ BF07285A36          /dev/dsk/c0t6d0    0/2/1/0.6.0  69464  /dev/vg00
    COMPAQ BF07288576          /dev/dsk/c0t5d0    0/2/1/0.5.0  69464  /dev/vg00
File System layout
    LVM Device file            mount point     size  fs type
    /dev/vg00:
    /dev/vg00/lvol1            /stand          304   hfs
    /dev/vg00/lvol2            swap            4096
    /dev/vg00/lvol3            /               208   vxfs
    /dev/vg00/lvol4            /tmp            4048  vxfs
    /dev/vg00/lvol5            /home           40000 vxfs
    /dev/vg00/lvol6            /opt            10000 vxfs
    /dev/vg00/lvol7            /usr            50000 vxfs
    /dev/vg00/lvol8            /var            4608  vxfs
    /dev/vg00                  unallocated     25616
Swap configuration
    type       size  priority  device/location
    dev        4096     1      /dev/vg00/lvol2
Kernel Configuration
    The following drivers or parameters are configured into your system's
    kernel.  After installing HP-UX, use the sam(1m) command to configure
    the following items into the kernel:
        STRMSGSZ                65535
        create_fastlinks            1
        dbc_max_pct                20
        dbc_min_pct                20
        default_disk_ir             1
        dnlc_hash_locks           512
        hfs_max_ra_blocks          20
        hfs_max_revra_blocks       20
        hfs_ra_per_disk           256
        hfs_revra_per_disk        256
        max_thread_proc          2048
        maxdsiz              3221225472
        maxdsiz_64bit        274877906944
        maxfiles                 2048
        maxfiles_lim             2048
        maxssiz              100610048
        maxssiz_64bit        1073741824
        maxswapchunks           16384
        maxtsiz              1073741824
        maxtsiz_64bit        4294967296
        maxuprc                  3277
        maxvgs                     80
        msgmap                   5122
        msgmax                  32768
        msgmnb                  65536
        msgmni                    512
        msgseg                  20480
        msgssz                    128
        msgtql                   5120
        nfile                    8192
        nflocks                  2048
        ninode                   8192
        nkthread                 6000
        nproc                    4096
        npty                      200
        nstrpty                   200
        nswapdev                   25
        semmni                   4096
        semmns                   8192
        semmnu                   4092
        semume                    512
        shmmax               1073741824
        shmmni                    512
        shmseg                    512
        vps_ceiling                64
        vx_fancyra_enable           1
        vx_ncsize                8000
System Information
    The following parameters were set on the configured target:
        hostname:           hpux
        IP address:         192.168.0.102
        subnet mask:        255.255.255.0
        gateway IP address: 192.168.0.1
        time zone:          GMT0BST
        DNS domain name:    internal
        DNS IP address:     8.8.8.8
Alver
Unread postby Alver » Mon Jan 30, 2017 7:31 am
Oh, heh. Yeah, this is (probably) one of the examples why I stopped using the rubbish from connect.org.uk. There's packages in there that would make your eyes bleed. Missing files, badly labeled stuff, wrong permissions, you name it. Not to say that everything on there is bad - that wouldn't be nice to many of the package maintainers - but there is zero quality control. :roll:
Just don't bother with it. Whatever they have on there, you can build it with pkgsrc yourself. Cleaner, more up to date, easier to maintain, safer. My old post on this is for a rather older version of pkgsrc and gcc, but it's still fairly relevant, I think. I probably have a tarball with my pkgsrc sources+binaries tree up somewhere still.
while (!asleep()) sheep++;
khalidschofield
Unread postby khalidschofield » Mon Jan 30, 2017 9:13 am
Yeh the permissions are a mess had loads of issues with file permissions needing to be fixed. I have a copy of your alverware downloaded onto my c8000. I'll read up on it to see how to build using the tree.
Return to “HP/DEC/Compaq”
