building current CDE on Alpha
bifo
Unread postby bifo » Mon Nov 14, 2016 5:48 pm
CDE's ancient, but that means that it should run quite well on old hardware. it's also open source now, along with motif. and i've been banging my head against building it on my 3000 running openbsd 6 for the last week. can anyone else try building it? doesnt really matter what system you're running so long as its unix and satisfies the dependencies, i'm just curious about errors it might throw.
also if anyone wants an account shoot me a pm, i'm not sure when i'll get around to it but its a pretty well robust system with a lot of languages and games installed.
zahal
Re: building current CDE on Alpha
Unread postby zahal » Tue Nov 15, 2016 6:53 am
Hello,
I have OpenBSD on my DS15, but as far as I know, there is no X support yet. So even if you manage to build CDE it would not work (correct me if I'm wrong).
Sitting in a room.....thinkin' shit up. :evil:
:O2: 400MHz R12k - :320: Dual 600MHz PIII - HP Alphaserver DS15 - Digital DECstation5000/133 - Dell T3500 - Apple G4 Cube dual 500MHz/GF6200 - Newton Messagepad 2100 - Apple PowerBook 2400c/G3@240 - Apple PowerMacintosh 6100/66 - Apple PowerMacintosh 6500/G3@500MHz - Apple Workgroup Server 9150/120 G3@280 - Apple Macintosh IIfx - Apple Macintosh LC475 (OC Full 040 33MHz) - Apple Macintosh Color Classic (Full 040 40Mhz Mystic upgrade) - Sun Cobalt Cube 3 - EBOX 3300A-JSK - Tadpole RDI UltraBook IIi - Compaq Armada 4120 - Digital HiNote Ultra II - HP OmniBook 425 - HP 200LX - Crossbeam C12
Unread postby foetz » Tue Nov 15, 2016 7:01 pm
why not using the original tru64? it comes with cde by default
Krokodil
Unread postby Krokodil » Fri Nov 18, 2016 10:04 pm
zahal wrote:Hello,
Well the story actually is that X is "broken". I don't see anyone taking the initiative to fix it either unfortunately. So I doubt it will ever be before someone decides to drop kick Alpha out of OpenBSD.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
astouffer
Unread postby astouffer » Sat Nov 19, 2016 10:01 am
Have you thought about trying NetBSD? I used to run X and even some Tru64 programs like Netscape. OpenBSD on Alpha always seemed to freeze up after a day or so.
If you're feeling adventurous you could always give OpenVMS a try.
Unread postby Raion-Fox » Sat Nov 19, 2016 5:44 pm
I second the NetBSD recommendation since with broken X on OpenBSD you've no chance of getting CDE running.
Krokodil
Unread postby Krokodil » Sun Nov 20, 2016 9:58 am
astouffer wrote:Have you thought about trying NetBSD? I used to run X and even some Tru64 programs like Netscape. OpenBSD on Alpha always seemed to freeze up after a day or so.
I have OpenVMS on mine, the only thing that sucks about it, is the total lack of ready to use software. There is that one guys site, but I got completely swamped trying to sort through it and all the dependencies.
TruHobbyist
Unread postby TruHobbyist » Tue Nov 22, 2016 12:28 am
Krokodil wrote:I have OpenVMS on mine, the only thing that sucks about it, is the total lack of ready to use software. There is that one guys site, but I got completely swamped trying to sort through it and all the dependencies.
"... give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime ... "
https://en.wikibooks.org/wiki/Porting_O ... to_OpenVMS
For us who love non-mainstream platforms you either get to teach yourself to fish or you'll end up in frustration that inevitably leads to completely turning away from it.
Krokodil
Unread postby Krokodil » Mon Nov 28, 2016 9:50 pm
If only we all had infinite time to spend on this stuff.
This guy does not and I really don't like it when I spend time on something and don't get anywhere.
VMS is so crusty now that it often doesn't play well with other systems, I often have SSH lock up when connecting from IRIX. The SSH ciphers are deprecated and the logicals screw with Filezilla and WinSCP. Sometimes I just want to kick it out the window.
bifo
Unread postby bifo » Mon Dec 26, 2016 11:37 am
foetz wrote:why not using the original tru64? it comes with cde by default
Had to netboot the openbsd installer in order to get it working, been fighting with various drives ever since. I picked up a toshiba xm-5701b last week that should work, I think, but I'm still waiting for more hard drives to arrive. I can confirm that ultra320/SCA to 50 pin adapters work fine on my 3000/400, but beware of buying the wrong SCA drive, anything with LVM connectors won't work. I've had good luck with old maxtor atlas drives so far.
The end goal is to have two drives in it, one running tru64 and the other running openvms. I can definitely report that X works via remote session and xming, but on a 133mhz system there's not a lot of point trying to use it with a modern system like openbsd while I expect decwindows to work reasonably well on openvms and cde on tru64. Easier just to use screen -r for now, I decided.
Return to “HP/DEC/Compaq”
