HP Apollo 715/50 serial access
55cancri
Unread postby 55cancri » Tue Sep 08, 2015 9:49 am
Hello :-)
I got an Apollo 715/50 and try to get access to it through a serial cable. I startet the console-session with my Octane and just plugged the serial-cable out of my AlphaStation 200 right into the Apollo 715 and startet it. But nothing happens. Serial access to my AS200 always worked flawless.
The error-LEDs of my Apollo just shows that everything seems to be ok and it trys to boot from serveral things (disk, network and so on ...). But there is no disk yet and my two LED-monitors show nothing at all, no matter how I switch the DIPs of the internal graphicscard.
Question : What can I do? ^^
Re: HP Apollo 715/50 serial access
Unread postby robespierre » Tue Sep 08, 2015 10:49 am
are you using a null-modem cable?
55cancri
Unread postby 55cancri » Tue Sep 08, 2015 11:28 am
Hmmm, yes. I used it for serial access to my AlphaStation last time.
55cancri
Unread postby 55cancri » Wed Sep 09, 2015 5:27 am
Now I have a CRT-Monitor here. Its an 15inch IBM from the Netvista-Desktop-late-90's age, but still no picture. Does it not display anything until a Keyboard is plugged in? Oh, man ...
It looks like I have buy one of those crazy HIL Keyboards.
55cancri
Unread postby 55cancri » Thu Sep 10, 2015 1:07 am
Yes, I forgot that this IBM-PC Monitor is not sync-on-green capable. I also tried my Fujitsu Siemens B19-5 TFT, which I use for my SGI Workstations through a 13w3 adapter, so that means that it is sync-on-green-capable, but no picture with my Apollo :?
The Apollo 715/50 has an internal graphics card with a DIP-switch to chance resolutions ... like 1024x768-72Hz. That shouldn't be a problem for my TFT-Monitor, i guess. And the error LED indicate that the computer tries to boot from Disk. I think, it wouldn't do that if there is something wrong with the CPU or RAM.
Hmm, now I will just wait for my HIL Keyboard. :oops:
Unread postby Trippynet » Thu Sep 10, 2015 3:25 am
Don't forget that a lot of TFTs have trouble with refresh rates above 60Hz. I'd try it with that first of all if possible.
55cancri
Unread postby 55cancri » Sat Sep 12, 2015 3:59 am
I did it!!!!!!!!!!!!!!! Yes!!!!
The HIL Keyboard was delivered this morning and since I still have no output on the screen, I had to stop the boot process, navigate through the menu and chance the console output blindly! It took two hours! My nerves are wrecked, but i'm happy 8-)
ivelegacy wrote:ups, I have an 715-EISA expansion for sale, it's here collecting dust, so you can have it for just 1 euro + shipping.
I already have two of those, but thanks :-)
miod
Unread postby miod » Sun Sep 13, 2015 8:58 am
55cancri wrote:The HIL Keyboard was delivered this morning and since I still have no output on the screen, I had to stop the boot process, navigate through the menu and chance the console output blindly!
Didn't you know you could press the tab key repeatedly during PROM initialization to have it cycle through video modes, until you'd find one your screen would display? :mrgreen:
55cancri
Unread postby 55cancri » Tue Sep 15, 2015 9:32 am
Hmm, the 715/50 only has a DIP-Switch for different resolutions and I also googled all these tricks to change the Outputdevice, but none of these tricks work on the 715/50 type. Like pressing the TOC-Button at boottime or removing the graphicscard, which isn't possible.
You can even totally mess the output up if you type somthing wrong into the outputvariable of the Bios. So, I think the Apollo 715/50 is a pretty nasty machine, but now I finally have serial output :-)
55cancri
Unread postby 55cancri » Wed Sep 23, 2015 4:24 am
Hmmm, the 715-Manual says nothing about 'restoration' or setting back to default variables : http://ftp.parisc-linux.org/docs/platfo ... ndbook.pdf
... and not even how to chance resolutions with the tab key, or a 'monitor' bootstrap command is mentioned there. It looks like the 712 is not so very similar to the 715. The 712 came two years later.
Check out openpa.net :-)
Unread postby robespierre » Wed Sep 23, 2015 8:14 am
The 712 is most similar to the second generation of 715 machines like the 715/100XC.
55cancri
Unread postby 55cancri » Thu Sep 24, 2015 5:24 am
ivelegacy wrote:I also remember the TOC button: if you hold if for 10 seconds after you hit power, then the HP715/50 should switch the console to the first serial
Sorry, but this also doesn't work ^^ I tried it myself after reading this ---> http://wiki.NetBSD.org/ports/hp700faq/
Man, this machine just throws every rock in your way it can ^^
55cancri
Unread postby 55cancri » Fri Sep 25, 2015 7:14 am
Wait! I will test this later ... now I have another Problem.
I installed NetBSD 5 over Network which worked fine so far. But when I try to boot this fscking 715 from disk, which costs two weeks of sweat and tears, it just stops at single user mode and I don't see why. No error messages, rc.conf and fstab are configured.
fstab :
/dev/sd0a / ffs rw 1 1
/dev/sd0b none swap sw,dp 0 0
/dev/sd0d /usr ffs rw 1 2
kernfs /kern kernfs rw
ptyfs /dev/pts ptyfs rw
procfs /proc procfs rw
'rc_configured=YES' is enabled in rc.conf
Return to “HP/DEC/Compaq”
Users browsing this forum: Semrush [Bot] and 3 guests
