tru64 system disk clone
Unread postby foetz » Sat Jan 31, 2015 10:09 am
since my disk clone script for irix was quite popular i figured i could also share the one for osf. here it comes:
#   R-A-C OSF/1 AdvFS system disk clone
#   this script generally assumes disk id 1 and that your target disk is
#   partitioned already. if not run:
#   disklabel -wr -t advfs /dev/rdisk/dsk1c
#   then partition your disk using diskconfig or disklabel.
#   this script expects the following partitions:
#   - a: root, rather small.
#   - b: usr, the big one. everything else goes there.
#   - d: swap, not necessary for the cloning.
#   if you should not have var as part of the usr domain change the
#   related parts accordingly.
#   if you should use the clone with a different id than the original
#   remember to change the swap entry in /etc/sysconfigtab on the clone.
echo preparing ...
rmfdmn -f clone_usr
rmfdmn -f clone_root
cd /mnt
mkdir dr du dv
echo creating clone root domain ...
mkfdmn /dev/disk/dsk1a clone_root
echo creating clone root fileset ...
mkfset clone_root root
mount_advfs clone_root#root /mnt/dr
echo creating clone usr domain ...
mkfdmn /dev/disk/dsk1b clone_usr
echo creating clone usr fileset ...
mkfset clone_usr usr
mount_advfs clone_usr#usr /mnt/du
echo putting var into the usr domain ...
mkfset clone_usr var
mount_advfs clone_usr#var /mnt/dv
echo dumping ...
vdump 0f - / | ( cd /mnt/dr ; vrestore xf - )
vdump 0f - /usr | ( cd /mnt/du ; vrestore xf - )
vdump 0f - /var | ( cd /mnt/dv ; vrestore xf - )
echo fixing domains for the clone ...
cd /mnt/dr/etc/fdmns
mv root_domain root_domain_old
mv usr_domain usr_domain_old
mv clone_root root_domain
mv clone_usr usr_domain
echo cleaning up ...
cd /mnt
umount dr
umount du
umount dv
rmdir dr du dv
echo all done
exit 0
tingo
Re: tru64 system disk clone
Unread postby tingo » Sat Feb 14, 2015 10:39 am
Too many versions of the irix clone script show up in search. Can anyone point to the most up to date version?
Torfinn
Unread postby Raion-Fox » Sat Feb 14, 2015 3:15 pm
tingo wrote:Too many versions of the irix clone script show up in search. Can anyone point to the most up to date version?
This is a script for DEC OSF/1 also known as Tru64, not IRIX.
Unread postby foetz » Sat Feb 14, 2015 3:57 pm
TeamBlackFox wrote:This is a script for DEC OSF/1 also known as Tru64, not IRIX.
i guess he referred to my comment about the irix script in the first post.
the original is there: viewtopic.php?p=65901#p65901
that's also the one i recommend. all modifications that came later did not add actual functionality.
Unread postby josehill » Sat Feb 14, 2015 4:35 pm
foetz wrote:all modifications that came later did not add actual functionality.
Pretty much the story of my life, right there! :lol:
Unread postby foetz » Sun Feb 15, 2015 5:24 am
oh did you make on of the later versions? :P
Return to “HP/DEC/Compaq”
