Help with Tru64 and DNS
logix
Unread postby logix » Mon Jan 05, 2015 12:00 pm
Hi!
I have installed Tru64 with patch kit 4 on a Alpha DS10L and so far so good, but i can't get DNS to work properly. I can ping adresses with the IP number but not use DNS. I have tried to set DNS in nsswitch.conf and svc.conf but with no luck, and i have nameserver x.x.x.x in resolv.conf
Re: Help with Tru64 and DNS
Unread postby foetz » Mon Jan 05, 2015 12:07 pm
please tell us how you set the network up on the alpha. e.g. local ip, gateway ip, dns ip ...
logix
Unread postby logix » Mon Jan 05, 2015 12:13 pm
i took a easy way with the network setup, did IFCONFIG_0="DYNAMIC" in rc.config and that seemed to work with dhcp. But i have tried to setup with sysman but i have no clue how to fix the dns problem i have.
Unread postby foetz » Mon Jan 05, 2015 12:21 pm
first assign a static ip. then make sure you have the right default route and then try again
Unread postby uunix » Mon Jan 05, 2015 12:38 pm
There must also be a resolve.conf (or similar) so it knows how to resolve name to IP.
smj
Unread postby smj » Mon Jan 05, 2015 12:40 pm
Also make sure your netmask and broadcast address are being set correctly, whether your interface is being configured statically or via DHCP. For instance I use network 10 internally (e.g. hostA = 10.10.10.132) with a 24-bit netmask. Naive software, or a not-quite-right DHCP agent, might use the pre-CIDR* default netmask of 8-bits, which would cause all kinds of problems...
* Edit: Not using the class-based default netmask doesn't necessarily imply CIDR. We certainly used longer netmasks ("subnetting") on class A/B networks in the late 80s / early 90s...
Unread postby foetz » Mon Jan 05, 2015 12:56 pm
uunix wrote:There must also be a resolve.conf
there is
logix
Unread postby logix » Mon Jan 05, 2015 1:27 pm
ok i have setup the ip static now and redone all the network settings, and finally it can ping www.google.com :) thank you guys!
Time to dig in to the Tru64 world once again!
Unread postby foetz » Mon Jan 05, 2015 1:27 pm
good to hear, have fun :D
logix
Unread postby logix » Mon Jan 05, 2015 1:43 pm
By the way is it possible to get the latest/last patch kit 6? well it does not improve that much either way from patch kit 4 i'm using now.
tingo
Unread postby tingo » Thu Jan 08, 2015 6:40 am
Since I've never had my fingers on a True64 machine: is the actual name resolve.conf? Or is it resolv.conf like in many other unixes?
Torfinn
Unread postby uunix » Thu Jan 08, 2015 3:12 pm
my bad, it's normally resolv.conf
Alver
Unread postby Alver » Fri Jan 09, 2015 4:33 am
logix wrote:By the way is it possible to get the latest/last patch kit 6? well it does not improve that much either way from patch kit 4 i'm using now.
It is definitely possible to find it... but you'd have to ask the right people on the right IRC channel :) unless you have a 5.1b4 kit from the (now deceased) Tru64 Hobbyist program, you still need a valid support contract to get it via the official channels.
while (!asleep()) sheep++;
Return to “HP/DEC/Compaq”
