[Wanted] Is the DECStation 5000/25 bios allowed to share
lucky7456969
Unread postby lucky7456969 » Tue Nov 11, 2014 9:00 pm
If it is allowed to share, and if you wish, please share with me.
Otherwise, just forget it.
Don't know if the rom image is copyrighted or not?
Thanks
Jack
smj
Re: [Wanted] Is the DECStation 5000/25 bios allowed to share
Unread postby smj » Tue Nov 11, 2014 10:05 pm
You mean like this one here?
The Personal DECstation 5000/25 is a MIPS-based workstation. You are aware it's not going to run Windows, right? Forgive me if you already know that, it's just odd to have somebody requesting "BIOS" for a MIPS-based workstation... Is there a specific problem you've run into that you think later firmware than what's already loaded would correct?
lucky7456969
Unread postby lucky7456969 » Tue Nov 11, 2014 10:36 pm
hello smj,
glad to hear a quick response, did you mean decstation 5000/25 hasn't got any firmware inside?
If so, thanks a lot for telling me that. I have been looking for it as if it was there
Jack
smj
Unread postby smj » Wed Nov 12, 2014 12:12 am
All DECstations have firmware, but none of them provide the kind of window-driven setup that PC BIOS does. While there's usually nothing wrong with updating to the last released firmware, there's also usually not a lot to be gained unless you've run into a specific problem and found an indication that a different firmware release will fix it. By and large, the firmware on these systems does little more than load and execute software (from disk, tape, CD, or the network), examine/modify memory, dump the processor state, manage a few variables in NVRAM, and perhaps a few other low-level tasks.
Let me ask a different question - what do you expect to do with any DECstation firmware you can find?
lucky7456969
Unread postby lucky7456969 » Wed Nov 12, 2014 2:03 am
smj wrote:Let me ask a different question - what do you expect to do with any DECstation firmware you can find?
:) I will pop it into an emulator called gxemul, it is not easy to compile. But it took me half a year or so...
Thanks
Jack
Unread postby ClassicHasClass » Wed Nov 12, 2014 8:07 am
Really? It built out of the box for me on my G5.
Unread postby foetz » Wed Nov 12, 2014 2:10 pm
ClassicHasClass wrote:Really? It built out of the box for me on my G5.
same here, not a single prob even without gcc
lucky7456969
Unread postby lucky7456969 » Mon Nov 24, 2014 2:39 am
I actually once completed compiling it successfully, but I messed it up again. So it took some time again
Return to “HP/DEC/Compaq”
