Mounting CD ROM in Digital Unix...
yetanother**ixuser
Unread postby yetanother**ixuser » Sat Oct 25, 2014 6:02 am
I want to upgrade the firmware on this old Alphastation 200, but i'm unable to mount the firmware cd.
# file /dev/rrz*c
rrz6c: character special (8/6146) SCSI #0 RRD43 disk #48 (SCSI ID #6 ) (SCSI LUN 0 ) errors = 0/6 offline
mount -t cdfs -o noversion /dev/rz6c /cdrom
/dev/rz6c on /cdrom: No such device
# uname -a
OSF1 alphastation V4.0 386 alpha
whats wrong?
no plan
Stoo
Re: Mounting CD ROM in Digital Unix...
Unread postby Stoo » Sat Oct 25, 2014 8:19 am
Because it's /dev/rrz6c not /dev/rz6c?
:Octane2: Octane2 Dual R14K 600Mhz, 4GB RAM, VPro V12, DCD, PCI Card Cage, GBit Ethernet
:Indigo2IMP: Indigo2 R10K 195MHz, 1GB RAM, Maximum Impact, I2V
The boxen are breeding... help!
yetanother**ixuser
Unread postby yetanother**ixuser » Sat Oct 25, 2014 8:33 am
Stoo wrote:Because it's /dev/rrz6c not /dev/rz6c?
/dev/rrz6c is the char device and /dev/rz6c is the correspondig block device for mounting.
no plan
Unread postby foetz » Sat Oct 25, 2014 8:34 am
according to the digital unix 4.0d docs not using the raw device is correct
mount -rd -t cdfs -o rrip /dev/rz4c /usr/share/doclib/online
does the cdrom work otherwise? i mean you're sure the gear is fine?
yetanother**ixuser
Unread postby yetanother**ixuser » Sat Oct 25, 2014 9:32 am
foetz wrote:according to the digital unix 4.0d docs not using the raw device is correct
yes, the drive is ok, downgraded to digital unix 3.0F. it seems that cdfs support is not included in the standard dgux kernel, which give me some warm lols *gg*. after the rebuild the mount command works. unfortunatly the files on the cdrom are corrupt.
so next question is, how do i mount a fat formated floppy without installing mtools?
no plan
Unread postby foetz » Sat Oct 25, 2014 11:16 am
yetanother**ixuser wrote:downgraded to digital unix 3.0F. it seems that cdfs support is not included in the standard dgux kernel
erm, wait. are you having that problem with dg/ux or digital unix?
yetanother**ixuser
Unread postby yetanother**ixuser » Sun Oct 26, 2014 2:04 am
ahh sorry, forgot that data general even exists. this is about digital unix.
no plan
Return to “HP/DEC/Compaq”
