gxemul with ultrix
gxemul with ultrix
Unread postby foetz » Fri Oct 03, 2014 10:54 pm
yesterday was a holiday here so i figured why not spending some time with ultrix :D
compiled and fired up gxemul on osx and went ahead ...
all fine except for the constant 100% cpu load caused by gxemul. maybe anyone else encountered that?
Re: gxemul with ultrix
Unread postby ClassicHasClass » Sat Oct 04, 2014 11:21 am
gxemul does use a lot of CPU. It's just a very heavyweight emulator with no dynamic code compilation that I know of.
Unread postby foetz » Sat Oct 04, 2014 4:46 pm
so you mean it using 100% all the time is how it is? :P
Unread postby ClassicHasClass » Sat Oct 04, 2014 6:12 pm
That's exactly what I mean. That's exactly what it's doing on my G5 right now (it's spreading it over four cores, but it's clearly pegging one).
Unread postby robespierre » Sat Oct 04, 2014 6:34 pm
When emulating a computer, there is usually no upper limit to the amount of CPU consumed.
The emulator works on a "best-effort" basis, and runs the virtual CPU as fast as it can. This is not related to the useful work on the virtual CPU, since it probably busy-waits for something to happen (interrupts). In hardware you would keep the clock running all the time, and be ready to service an interrupt as soon as it happened. The only way to limit the (useless) consumption of host CPU resources is to engineer a completely new virtual "device" that does not exist in the original hardware at all, which stops the clock and everything else until something happens. This almost always requires a new device driver in the emulated OS.
Unread postby foetz » Sat Oct 04, 2014 7:15 pm
oh yeah very nice explanation, thanks :-)
Alver
Unread postby Alver » Wed Oct 22, 2014 6:24 am
robespierre wrote:When emulating a computer, there is usually no upper limit to the amount of CPU consumed.
I'm afraid (and foetz will be happy) that this statement is simply not true :) I have ultrix running in SIMH on Linux (ULTRIX V4.0 (Rev. 161) - and yes, SIMH exists on OSX as well) and it doesn't consume 100% CPU. It all comes down to how the emulator implements the idle instructions of the emulated OS/chip. I'm far from an expert on how these things get implemented, but rest assured, I've made sure none of my emulated VAXen had the 100% CPU issue before setting them loose 24/7. :D
while (!asleep()) sheep++;
Unread postby foetz » Wed Oct 22, 2014 7:27 am
indeed that's good news :D
grabbed simh already and will give it a try ...
Alver
Unread postby Alver » Wed Oct 22, 2014 7:56 am
foetz wrote:indeed that's good news :D
Make sure to get the "beta" 4.x simh, it's massively improved since the "old" 3.9 branch.
My ultrix simh vax.ini:
LOAD -r /srv/vax/ka655x.bin
ATTACH nvr /srv/vax/CASTOR/nvram.bin
SET RQ0 RA90
SET RQ1 RA90
ATTACH RQ0 /srv/vax/CASTOR/VMS-RQ0.dsk
ATTACH RQ1 /srv/vax/CASTOR/VMS-RQ1.dsk
SET CPU 32M
SET CPU IDLE
SET CPU CONHALT
SET RL DISABLE
SET TS DISABLE
SET TQ TK50
ATT TQ0 /srv/vax/CASTOR/Ultrix_4.0_Supported.tap
ATT TQ1 /srv/vax/CASTOR/Ultrix_4.0_Unsupported.tap
SET XQ MAC=AA:00:04:1F:0D:69
ATTACH XQ tap:tap-castor
DEP BDR 0
BOOT CPU
EXIT
The disk and network stuff is specific, but you get the idea :)
Unread postby robespierre » Fri Oct 24, 2014 4:37 pm
Alver wrote:I have ultrix running in SIMH on Linux (ULTRIX V4.0 (Rev. 161) - and yes, SIMH exists on OSX as well) and it doesn't consume 100% CPU. It all comes down to how the emulator implements the idle instructions of the emulated OS/chip. I'm far from an expert on how these things get implemented, but rest assured, I've made sure none of my emulated VAXen had the 100% CPU issue before setting them loose 24/7. :D
Indeed, it is a rare CPU that has "idle instructions". That isn't how hardware works: Even when the system is waiting "idle" for an event, it is still running code, and it still needs to update counters/timers.
See these links for some insight into how brittle and unreliable the heuristics used by SIMH are:
http://github.com/simh/simh/issues/80
http://www.mail-archive.com/simh@traili ... 01231.html
This approach is very VAX-like. "We've got so many instructions, we'll never have to use each one more than once!" Expecting it to work on a more rational architecture is a pipe dream.
miod
Unread postby miod » Sat Oct 25, 2014 5:20 am
robespierre wrote:Indeed, it is a rare CPU that has "idle instructions".
Actually, the vax doesn't have an idle instruction. But Ultrix and VMS' idle loop perform an ``unnatural'' and easy to identify sequence of instructions, which is easy to detect in an emulator to know that it is harmless to suspend emulation until an interrupt occurs.
Return to “HP/DEC/Compaq”
