AlphaStation 500 memory question
tenox
Unread postby tenox » Wed Feb 12, 2014 8:18 pm
Hi,
I have bought a memory kit for my AlphaStation 500, but I have a following problem:
The difference is enough so that the module just won't fit.
Is there a difference between Digital and Compaq versions of AS500?
Do you think I could just cut it out? Would it work, or am I better replacing the memory?
Thanks!!
Re: AlphaStation 500 memory question
Unread postby jan-jaap » Thu Feb 13, 2014 12:57 am
Top part is EDO, the bottom part (KM44C4000A) is FPM RAM (although the packaging looks like SDRAM). Anyway, different technologies.
Some systems supported both, others didn't (e.g. Indigo2 won't take EDO even if it physically fits). In this case, if it doesn't fit physically, I guess it's obvious it's not going to work.
smj
Unread postby smj » Thu Feb 13, 2014 12:24 pm
What j-j said - those notches and the matching bits in the sockets are intentional keying to keep you from using the wrong type of memory, similar to their use in PCI cards to keep you from putting 5V parts in a 3.3V system, etc. Resist the temptation to cut! :)
tenox
Unread postby tenox » Thu Feb 13, 2014 9:27 pm
Thanks a lot for explanation! I won't do it and simply will return the memory.
Do you know a good source for the correct memory for my AS500?
Many thanks!!
Return to “HP/DEC/Compaq”
