HP C8000, PA-8800 1GHz, 4GB, FireGL X1
gkl
Unread postby gkl » Fri Feb 04, 2011 12:16 pm
I just bought a HP C8000 off of ebay (for dirt cheap, and more are still listed), and thus begins my journey into the mysterious world of PA-RISC. Came with a PA-8800 1GHz, ATI FireGL X1 (256MB), and 73+146GB Ultra320 disks.
Processors:
Active:                2
Total:                 2
CPU Version:             PA 8800 CPU Module 3.2
Clock Frequency:         1000 MHz
Machine Identification:  3662404977
Hardware Model:          9000/785/C8000
Kernel Width Support:    64
(March 2011 edit--upgraded to 8x1GB DDR-266 from 8x512MB)
Physical Memory:         8197.3 MB
Real Memory:
  Active:                293059.3 KB
  Total:                 368693.1 KB
Virtual Memory:
  Active:                512265.4 KB
  Total:                 609681.1 KB
Free Memory Pages:       1456097 at 4 KB/page
Swap Space:
  Avail:                 4096 MB
  Used:                  419 MB
0/2/1/0     mpt         SCSI Ultra320 A6961-60011
0/2/1/1     mpt         SCSI Ultra320 A6961-60011
0/3/1/0     hcd         NEC USB Interface
0/3/1/1     hcd         NEC USB Interface
0/3/1/2     ehci        NEC USB Interface
0/3/2/0     side_ba     CMD IDE controller
0/3/2/0.0   side        IDE
0/3/2/0.1   side        IDE
0/3/3/0     iether      HP  PCI 1000Base-T Built-in
0/4/0/0     gvid_core   HP-UX Console Support for FireGL Graphics card
0/4/0/1     gvid_core   HP-UX Console Support for FireGL Graphics card
17          asio0       Built-in RS-232 Interface
18          asio0       Built-in RS-232 Interface
I had no idea these things are as large as they are, and they're shockingly silent given the fact that mine is pulling over 260W out of my wall just idling at login. Unfortunately the case is locked and I wasn't given the key, so I'll have to find some other way to open it up.
:Fuel: :O2: HP C8000, IBM RS/6000 43p 150, and lots of Suns in my collection
D-EJ915
Re: HP C8000, PA-8800 1GHz, 4GB, FireGL X1
Unread postby D-EJ915 » Fri Feb 04, 2011 8:28 pm
Congrats, they are great systems and yep very big and heavy haha.
Dennis Nedry
Unread postby Dennis Nedry » Fri Feb 04, 2011 9:50 pm
If that's one of those round keys with the (parallel) cuts down the outer side of the barrel...
I'm pretty sure you can defeat those by using a BIC pen with the cap removed from the end (or anything that fits snugly into the lock- so there's a fair amount of friction), by just jamming it in there and turning it in the direction the lock opens, then slowly pulling it out (while continuing to turn it).
I've defeated a few locks like that on other various keyless equipment.
If it's a bog standard pin/tumbler lock... You can defeat those easily enough with a bent jumbo safety pin (or anything else that retains it's shape under pressure) and a screwdriver... Google lock picking, it's easier then you might think. Paperclips might work, but they tend to bend before you can apply enough leverage to pop up the rear pins.
-DN
I've got butterfingers!
Unread postby SAQ » Fri Feb 04, 2011 10:45 pm
Dennis Nedry wrote:If that's one of those round keys with the (parallel) cuts down the outer side of the barrel...
-DN
Spring steel is the way to go.
gkl
Unread postby gkl » Sat Feb 05, 2011 10:25 am
Dennis Nedry wrote:I've defeated a few locks like that on other various keyless equipment.
I knew this worked for bike locks, but I wasn't sure about these kinds. From the looks of it, the case lock is only a 4-pin (whereas things like soda machines have 8 pins), so maybe it'll be easy to break into. Worst case, I ask HP if they can send me a replacement. I suspect they issued the same key for all of their C8000s.
Of more concern now is that apparently HP patches are now for support contract-holders only, and a lot of their free software offerings (e.g., Firefox 3.5) require system patches above what came on the 11i base install set. I have access to OpenVMS and Tru64 support, but I suspect I may be SOL and stuck with the limited 11i cds and upgrades I have.
Alas! It's still a fun ride. HP-UX feels a lot more like IRIX than, say, SunOS 8/9 did.
Unread postby guardian452 » Sat Feb 05, 2011 11:10 am
They may be the same for all HP workstations. I have a spare for my xw9300, if you think it will work you can have it.
Dennis Nedry
Unread postby Dennis Nedry » Sat Feb 05, 2011 2:58 pm
Likely. I'm not aware of any manufacture that makes per-machine key sets. I think that would cost them too much to make each lock unique for every computer shipped.
Either way, it should still work. I had to deal with one of those (4-pins, super-cheap lock) on a keyless rack about a week ago. It took me about 2 minutes to pull apart a BIC pen and widen the end with a pair of side cutters. Jam the end of the pen into the lock, slowly pivot it around the tumbler axis while turning it in the direction that it opens... 15 seconds later, the rack latch merrily popped up and the rack was open. Wasn't really part of my job at the time, but I had to say something when I saw them heading off to find a drill, a hacksaw, and a crowbar (they'd locked themselves out of the cabinet and had to get to the tape library to install fresh media).
-DN
gkl
Unread postby gkl » Sat Feb 05, 2011 4:16 pm
Dennis Nedry wrote:Either way, it should still work. I had to deal with one of those (4-pins, super-cheap lock) on a keyless rack about a week ago. It took me about 2 minutes to pull apart a BIC pen and widen the end with a pair of side cutters. Jam the end of the pen into the lock, slowly pivot it around the tumbler axis while turning it in the direction that it opens... 15 seconds later, the rack latch merrily popped up and the rack was open.
Wow, this actually worked exactly as quickly as you had said. Took me longer to find a pen than it did to actually get the lock open. That's one problem down; thanks for the tip!
jpanchal
Unread postby jpanchal » Sat Feb 05, 2011 9:56 pm
I have a J6750, and the new HP-UX patching policy is a pain (it's as bad as the new Oracle policy for Solaris...) - just to let you know, Debian runs a dream on PA-RISC hardware thanks to the folks at ESIEE, if you ever need a backup OS. :)
Alver
Unread postby Alver » Thu Feb 10, 2011 2:38 pm
gkl wrote:I just bought a HP C8000 off of ebay (for dirt cheap, and more are still listed), and thus begins my journey into the mysterious world of PA-RISC. Came with a PA-8800 1GHz, ATI FireGL X1 (256MB), and 73+146GB Ultra320 disks.
Are you sure it's an X1? C8000s 'officially' don't support those (or they're missing from the docs), it's usually either T2 or X3. Also, the X1 only had 128MB, afaik. :)
Nice machine! Welcome to the C8000 club. Quick hint: pkgsrc on HPUX 11.11 doesn't run too bad. :D
while (!asleep()) sheep++;
gkl
Unread postby gkl » Thu Feb 10, 2011 2:47 pm
Alver wrote:Are you sure it's an X1? C8000s 'officially' don't support those (or they're missing from the docs), it's usually either T2 or X3. Also, the X1 only had 128MB, afaik. :)
It may be an X3 then. I kept going back and forth because some docs refer to the "high end" graphics option as X1 and other docs say X3. If the X1 is limited to 128MB though, I've definitely got the X3.
Alver wrote:Welcome to the C8000 club. Quick hint: pkgsrc on HPUX 11.11 doesn't run too bad.
I'll have to give it a try. So far I've been able to find all the software I need precompiled, although one visualization package I use for work (VMD) crashes out if I try to run it with OpenGL support. Compiling it from source did not look fun, but I believe there is a pkgsrc for it.
jpstewart
Unread postby jpstewart » Fri Feb 11, 2011 8:24 am
The FireGL X1 is definitely mentioned in some of HP's docs for the C8000:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=408101&prodTypeId=12454&objectID=c00332698
Alver wrote:Also, the X1 only had 128MB, afaik.
The ATI FireGL X1-256p card (with 256MB) for the C8000 was offered as HP part number A9653A.
http://www.hp.com/workstations/irg/risc/HP_workstations_UNIX_options.pdf
I had a 256MB FireGL X1-256 in one of my PCs for the better part of the last decade, so I'm quite sure that ATI made FireGL X1 cards with 256MB. (They may also have been available with 128MB, too, but that's another matter. And what was supported in the C8000 is yet another question!)
gkl wrote:some docs refer to the "high end" graphics option as X1 and other docs say X3
Probably at the time of introduction, the high end was the X1 and then when ATI released the X3 it superseded the X1 as the high end option. The fine print in those docs show copyrights of 2004 and 2007.
HP C8000
D-EJ915
Unread postby D-EJ915 » Sat Feb 12, 2011 4:47 pm
jpanchal wrote:I have a J6750, and the new HP-UX patching policy is a pain (it's as bad as the new Oracle policy for Solaris...) - just to let you know, Debian runs a dream on PA-RISC hardware thanks to the folks at ESIEE, if you ever need a backup OS. :)
It does for now (5.0) but for 6.0 hppa is dropped :(
jpstewart
Unread postby jpstewart » Sun Feb 13, 2011 11:25 am
Just FYI: Debian 6.0 (aka Squeeze) was released a week ago, on Feb. 6, 2011. But Debian 5.0 (aka Lenny) is still available.
HP C8000
Alver
Unread postby Alver » Mon Feb 14, 2011 1:08 am
jpstewart wrote:The FireGL X1 is definitely mentioned in some of HP's docs for the C8000
Ah, funny... the internal HP "quickspecs" application mentions only T2 and X3. Maybe the support for that card was removed at some point :) regardless, if it's mentioned there, it should work.
Return to “HP/DEC/Compaq”
