funny card in compaq 1600 server
bradbobak
Unread postby bradbobak » Mon Jun 04, 2007 3:27 pm
Hi, I have come across a compaq server.. inside it has a pci card with a pcmcia slot populated with a pcmcia modem.. The card also has 4 AA batteries on it.. any ideas what the purpose of this card would be?
:Indy: :Indy: :Indigo2IMP: :O2: :Octane:
ipaddict
Re: funny card in compaq 1600 server
Unread postby ipaddict » Mon Jun 04, 2007 3:31 pm
A backdoor into the server if the power went out?
bradbobak
Unread postby bradbobak » Mon Jun 04, 2007 5:21 pm
Well the hard drives and cpu wouldn't have power.. maybe a way to reboot it on power off?
ipaddict
Unread postby ipaddict » Mon Jun 04, 2007 6:04 pm
bradbobak wrote:Well the hard drives and cpu wouldn't have power.. maybe a way to reboot it on power off?
Unless they're on battery backup, but access to a console and the BIOS/PROM/firmware would be enough to power the machine down safely or for simple remoate management.
TeeTylerToe
Unread postby TeeTylerToe » Wed Jun 06, 2007 12:20 pm
it's a remote management card
roosmcd
Unread postby roosmcd » Fri Jun 08, 2007 11:31 am
Yes, ILO-card. Allows you to dial into the server when it's crashed and do a reboot.
Nekochan.net -- where Linux is a four letter word.
bradbobak
Unread postby bradbobak » Fri Jun 08, 2007 1:22 pm
good to know :) thanks folks.
Return to “HP/DEC/Compaq”
