Sunfire v100 Config Card
Dans34
Unread postby Dans34 » Tue Nov 22, 2016 12:39 pm
Hello All
Dug out my old sunfire v100 motherboard recently to see if I could recase it , unfortunately seams I have misplaced the config card that came with it
Looking on ebay there are a few for the V240 & above, anyone know if this card would work or will I be able to use a generic smart card ?
Regards
Dan
:Octane: R12K/400 Octane, 1024MB, 36GB 15K MAX3036NC , MXI
johnnym
Re: Sunfire v100 Config Card
Unread postby johnnym » Wed Nov 23, 2016 6:47 am
Dans34 wrote:[...] Looking on ebay there are a few for the V240 & above, anyone know if this card would work or will I be able to use a generic smart card ?[...]
Hi Dan,
just tested this with the SC card of a V240 in a V100 and it seems to work, although the NVRAM contents are reset to their default values on startup. Both interfaces of the V100 have a MAC address based on the value that is printed on the SC card after startup.
BTW here are the part numbers of the SC cards if somebody wants an exact replacement:
  • Fire V240 - 370(-)5155-02
  • Fire V100 - 370-4285-02 (The SC card of my V100 has a hole near the chip, but this seems to be not relevant for the SC card reader, as the SC card from the V240 doesn't have this hole)
  • Netra X1 - 370-4285-01 (Just for reference as nearly identical to the V100)
Regards,
johnnym
| d | i | g | i | t | a | l | AXPpci33 AlphaStation 200 4/166 AlphaStation 255 300 Personal Workstation 500au AlphaServer DS20E
Dans34
Unread postby Dans34 » Wed Nov 23, 2016 1:32 pm
johnnym ,
thanks for trying the 2 different cards you had , I have purchased a card marked for use with a v240 from ebay , will report back when it arrives
Return to “Sun”
