ianj wrote:
If you can't find something in the standard repository,
SFE is the first place to look. Blastwave et. al. are severely out of date and were never intended for anything newer than Solaris 10. OpenIndiana is hosting an IPS repository of prebuilt SFE packages, which you should add:
Code:
pfexec pkg set-publisher -O http://staticdev.uk.openindiana.org:10002/ oi-sfe
It contains boost packages, but not opencv. Try building it yourself from the SFE spec. Also, keep in mind that
pkg list will only print packages installed on your system. You'll need to use
pkg list -a to print the entire contents of the repo.
Also be aware that the location and organization of oi-sfe might change. OpenIndiana hasn't finalized how they want to handle packages yet.
Thanks. I added the SFE repo with the pfexec command you specified above and this version had enough that the boost portions of code that were failing to compile previously actually compiled this time.
Digging around I found
http://staticdev.uk.openindiana.org:100 ... ion=SearchSo now, OpenCV is my only concern for this part of the project.
Edit: After installing pkg-config 0.25 from sunfreeware.com I did get OpenCV 1.0.0 to build, but not 1.1.
Hopefully there are no dependancies on newer versions.
But now there are other issues to deal with and should be doing other work anyway.
R.
死の神はりんごだけ食べる
アレゲはアレゲ以上のなにものでもなさげ -- アレゲ研究家
J5600, 2 x Mac, 3 x SUN, Alpha DS20E, Alpha 800 5/550, 3 x RS/6000, Amiga 4000 VideoToaster, Amiga4000 -030, 733MHz Sam440 AmigaOS 4.1 update 1. Tandem Himalaya S-Series Nonstop S72000 ServerNet.
Sold:
Cortex --->
http://www.facebook.com/pages/Cortex-th ... 11?sk=infoMinnie --->
http://www.facebook.com/pages/Minnie-th ... 02?sk=infoBook ---->
http://pymblesoftware.com/book/Github --->
https://github.com/pymblesoftwareVisit
http://www.pymblesoftware.comSearch for "Pymble", "InstaElf", "CryWhy" or "Cricket Score Sheet" in the iPad App store or search for "Pymble" or "CryWhy" in the iPhone App store.
