It is currently Sat May 18, 2013 11:51 am
Post new topic Reply to topic  [ 14 posts ]
Unread postPosted: Mon Mar 01, 2010 1:06 pm
I have two dead Sun Blade 1000s (I found that processors were screwed in too tight). I want to get my hands on a Sun Blade 2500, and I was wondering if the Blade 1000 ram would work in it.
Also, any ideas on what to do with these? Anyone know if the DVD drives will work in an Octane2 (Toshiba I *think*).
Thanks!
Sun Enterprise 420R: 4X450Mhz UltraSparc II, 4gb ram, Solaris
Sun Ultra 5: 360Mhz UltraSparc IIi, 256mb ram, OpenBSD
Unread postPosted: Mon Mar 01, 2010 1:19 pm
Not sure.
Look up the part number in http://docs.sun.com
Thanks!
I only have SCSI CD drives in my Blade 1000 and the same model works on SGI.
What to do with these..
QuakeIII Team Arena, Blender, Sun Studio, MySQL, PHP, MediaWiki, xchat, PostgreSQL, Oracle..
死の神はりんごだけ食べる
アレゲはアレゲ以上のなにものでもなさげ -- アレゲ研究家
Unread postPosted: Mon Mar 01, 2010 1:22 pm
*In* an Octane2? Not unless you do some metal work. But if they're SCSI DVD drives they should work fine *with* an Octane2 <which is what I think you actually meant anyway>. :D
Unread postPosted: Mon Mar 01, 2010 1:29 pm
The blade 1000 ram is compatible with the 2000, but not the 2500. The IIIcu and IIIi cpus have different memory controllers. The 1500/2500/v250/v210/v240/v440 etc, all use DDR 1 PC2700 ECC Registered.
Stuff.
Unread postPosted: Mon Mar 01, 2010 1:31 pm
Yep, thanks.
They are dead, so I am thinking I will just part them out or sell them both for ultra cheap in the DC Metro area.
Unread postPosted: Mon Mar 01, 2010 1:32 pm
Well I guess I will sell the ram to help pay for a 2500.
Unread postPosted: Mon Mar 01, 2010 4:10 pm
PC2100 in my 2500 board if I remember correctly but it is standard ECC DDR, super cheap and easy to come by
:Indy: :rx2600: :Indigo2: :Octane2: :hpserv: :hpserv: :O2: :Indigo2: :Indy: :Indy: system info on my website
Unread postPosted: Mon Mar 01, 2010 7:03 pm
Thats true, sorry. I had a typo. 2100 is what the manual calls for. I do have 2700 / 3200 mixed in my 2500 at the moment though. :)
Stuff.
Unread postPosted: Sat Mar 13, 2010 9:43 pm
How much ram and what are you asking for it? Just today I finally got off my duff and installed OpenSolaris on my SB1K. For some reason I thought it had 2G, but it's only 1G.
Unread postPosted: Wed Mar 24, 2010 9:22 am
A word of warning--pay attention to your OpenBoot revision and the CAS latency. I believe all of these PC2100-based Suns are only spec'ed at CL2.0, which is a bit harder to find than the CL2.5 PC2100 ECC that's all over.
I've had little trouble actually running a Blade 1500 with CL2.5 PC2100 with OpenBoot 4.9.x, but upgrading to 4.14 or higher will prevent the system from booting on anything that's not CL=2.0. I had to downgrade from 5GB to 1GB for this reason :(
:Fuel: :O2: HP C8000, IBM RS/6000 43p 150, and lots of Suns in my collection
Unread postPosted: Wed Mar 24, 2010 9:53 am
Strange that you did get more problems when upgrading openboot, I have had a 2500 since new with 16GB but at that time I hade 8 GB from Crucial and 8GB from Dataram which did not interleave fully, only the Dataram did work(CPU0) but after upgrading Openboot last summer the memory banks interleaves as they should which probably means that Openboot now properly reads the DRAM info from the DIMM.
============================ Memory Configuration ============================
Segment Table:
Base Address Size Interleave Factor Contains
0x0 8GB 16 BankIDs 0,1,2,3,4,5,6,7,8,9,10, 11,12,13,14,15
0x1000000000 8GB 16 BankIDs 16,17,18,19,20,21,22,23 ,24,25,26,27,28,29,30,31
Bank Table:
Physical Location
ID ControllerID GroupID Size Interleave Way
0 0 0 512MB 0,1,2,3,4,5,6,7,8,9,10,11,12,13 ,14,15
1 0 0 512MB
2 0 1 512MB
3 0 1 512MB
4 0 0 512MB
5 0 0 512MB
6 0 1 512MB
7 0 1 512MB
8 0 1 512MB
9 0 1 512MB
10 0 0 512MB
11 0 0 512MB
12 0 1 512MB
13 0 1 512MB
14 0 0 512MB
15 0 0 512MB
16 1 0 512MB 0,1,2,3,4,5,6,7,8,9,10,11,12,13 ,14,15
17 1 0 512MB
18 1 1 512MB
19 1 1 512MB
20 1 0 512MB
21 1 0 512MB
22 1 1 512MB
23 1 1 512MB
24 1 1 512MB
25 1 1 512MB
26 1 0 512MB
27 1 0 512MB
28 1 1 512MB
29 1 1 512MB
30 1 0 512MB
31 1 0 512MB
Memory Module Groups:
ControllerID GroupID Labels Status
0 0 MB/DIMM0
0 0 MB/DIMM1
0 1 MB/DIMM2
0 1 MB/DIMM3
1 0 MB/DIMM4
1 0 MB/DIMM5
1 1 MB/DIMM6
1 1 MB/DIMM7
============================ Environmental Status ============================
Fan Status:
Location Sensor Status
MB dimm-fan okay
F1 CPU0 okay
F2 CPU1 okay
F3 Outtake okay
F0 Intake okay
Temperature sensors:
HDD0 hard-disk0 okay
MB/0 Die okay
MB/1 Die okay
MB Ambient okay
MB Ambient okay
MB Ambient okay
MB Ambient okay
================================ HW Revisions ================================
ASIC Revisions:
Path Device Status Revision
/pci@1c,600000 pci108e,a801 okay 4
/pci@1d,700000 pci108e,a801 okay 4
/pci@1e,600000 pci108e,a801 okay 4
/pci@1f,700000 pci108e,a801 okay 4
System PROM revisions:
OBP 4.30.3 2009/06/08 13:21 Sun Blade 2500 (Silver)
OBDIAG 4.30.3 2009/06/08 13:34
/michael
risk.
Unread postPosted: Thu Mar 25, 2010 7:18 am
Hey, folks!
I'm interesting what is practical memory room limit for Blade 2500 RED one?
I presume that 2500 both Red and Silver share the same components (at least I/O), and the fall of memory size in twice from Silver to Red (from 16bg total (two 2gb quadpairs) with both cpu utilization in Silver to total 8gb (two 1gb quadpairs) in Red) as referred by manual is only OpenBoot program limitation, or even manual says configurations for which Sun was really responsible, am i right? Does anybody checked it?
P.S.: Can anobody also tell me about what specifially dictate the CPU difference in Red and Silver? Device recognizing in OpenBoot FCode?
:rx2600: (CHNPP node), custom build PC (duckstar host), one dead PowerBook G4 (nokacheflush host)
More info at my web page!
Unread postPosted: Thu Mar 25, 2010 7:40 am
I have a strong suspicion that you can load up a Red 2500 to at least 8x2GB. I've put 2GB sticks in my Red 1500 and gotten it up to 5GB (2x2048 and 2x512) of working, addressable memory despite the max being listed as 4x1024.
I'm pretty sure the only difference is a jumper on the motherboard. I would be very surprised if you couldn't put a 1.6GHz processor in a red's motherboard, switch that jumper setting, and have everything work fine. This is why I also suspect a red motherboard will take the full 16GB.
Unread postPosted: Thu Mar 25, 2010 2:16 pm
I would guess that the reason for Sun said 4.1024MB in Red was due to there was only 1024 DIMMs at the time.
Both my 1500 and 2500 silver have 8GB per CPU, 1500(8GB) and 2500(16GB)
/michael
risk.
