Installing Solaris 10 on E450
IndyFred
Unread postby IndyFred » Tue Aug 04, 2009 2:25 pm
I was wondering how easy/hard it is to install Solaris 10 for SPARC on an E450. I have never installed Solaris before, so this will be a new learning experience for me.
Any help or install guides would be most helpful.
Thanks!
Fred
porter
Re: Installing Solaris 10 on E450
Unread postby porter » Tue Aug 04, 2009 4:52 pm
IndyFred wrote:Any help or install guides would be most helpful.
1. Put CD one in the CDROM drive.
2. From the prom type "boot cdrom".
3. Follow on screen instructions.
Unread postby foetz » Tue Aug 04, 2009 5:03 pm
hehe, nice to the point.
it's really not harder than any other os installation.
IndyFred
Unread postby IndyFred » Tue Aug 04, 2009 5:11 pm
Okay I inserted the DVD and am installing it now.
Thanks everyone!
IndyFred
Unread postby IndyFred » Wed Aug 05, 2009 8:24 am
Okay the systems is reinstalled and on the internet.
What I do not understand is that I have eight hard drives for a total of 156GB. When I do the df -hk in terminal, all I see is the first hard drive. How do I see the other drives? Still new to Solaris and trying to learn as much as I can before my UNIX book arrives.
Thanks!
Fred
wolflord
Unread postby wolflord » Wed Aug 05, 2009 8:46 am
You probably need to run fdisk and make sure the other disks are labled and partitioned right. Also does you E450 have the full drive backplane or just the base 4 drive one? All your disks should atleast show up in /dev/dsk as cXtXd0sX where cX = controller # X, tX = target # X, d0 = lun 0, and sX = slice # X. From there you still need to make a filesystem on them and mount them.
WolfLord - :4D70G: :Octane2:
Unread postby SAQ » Wed Aug 05, 2009 9:12 am
Put the drives in a ZFS pool - it will make your life much easier.
IndyFred
Unread postby IndyFred » Wed Aug 05, 2009 9:36 am
wolflord wrote:You probably need to run fdisk and make sure the other disks are labled and partitioned right. Also does you E450 have the full drive backplane or just the base 4 drive one? All your disks should atleast show up in /dev/dsk as cXtXd0sX where cX = controller # X, tX = target # X, d0 = lun 0, and sX = slice # X. From there you still need to make a filesystem on them and mount them.
Thanks Wolflord, When I do a STOP-A, it shows all eight drives. I also have lights on all eight drives when I open the case. I think I have all the backplanes as the server did come with 18 drives but ten of them were bad. :-(
IndyFred
Unread postby IndyFred » Wed Aug 05, 2009 9:37 am
SAQ wrote:Put the drives in a ZFS pool - it will make your life much easier.
SAQ, how do I go about doing this? Should I do a custom Solaris 10 install?
Thanks again!
IndyFred
Unread postby IndyFred » Wed Aug 05, 2009 1:52 pm
Okay I have been scouring the internet for a guide on how to install Solaris 10 05/09 to make sure I am installing everything and it seems that some of the options offered I do not see. One option in particular is the disks section. On the internet, it shows which disk to install Solaris on. I never get that option.
Should I be using standard or Flash?
Thanks!
porter
Unread postby porter » Wed Aug 05, 2009 4:03 pm
IndyFred wrote:Should I be using standard or Flash?!
Standard interactive.
IndyFred
Unread postby IndyFred » Wed Aug 05, 2009 4:44 pm
Okay this is new. When I boot up (to reinstall Solaris 19) I now get this:
Configuring Devices.
WARNING: /pci@1f, 4000/scsi@3/sd@3, 0 (sd48):
corrupt label - bad geometry
Label says 35379200 blocks; Drive says 35378533 blocks
Using RPC Bootparams for network configuration information.
Attempting to configure interface hme0...
Skipped Interface hme0
What does this mean and how can I correct it under the EEPROM screen?
Thanks!
Fred
porter
Unread postby porter » Wed Aug 05, 2009 7:16 pm
Are the disks from foreign systems? You may want to run format on the disks, and reinstall again.
http://www.sun.com/bigadmin/content/submitted/format_utility.jsp
IndyFred
Unread postby IndyFred » Thu Aug 06, 2009 6:35 am
Thanks Porter. I will try this when I get home. The E450 does not have Solaris loaded on it yet.
Thanks!
Unread postby SAQ » Thu Aug 06, 2009 9:06 am
If you do a text console install you can put the root/boot on ZFS as well, and you can't do that under interactive (GUI).
I think that it might be easiest to label the disks (format program) from the GUI though - just bring up the root menu (right click on the desktop) and select "terminal"
Return to “Sun”
