O2 video input troubles
strandedinnz
Unread postby strandedinnz » Fri Apr 04, 2008 10:25 pm
Hiya,
I'm trying to use the composite input on my O2 to accept the composite output of my old Amiga 1200 and I can't get a picture in the videoin window :-(
If I pull a cable and plug in I'll get a slightly mashed still of the output
Same if I use my Commodore 128 .. no picture.
The O2 is fine as far as I can tell because if I put the output of the O2 into the input of the O2 and grab a piece of desktop as the video source it works great ... well as good as can be expected with composite!
So I think the O2 is just not synchronising to the signal coming in.
In VideoPanel I can adjust the Composite Vide Input Signal ... but what should I be tweaking ?
Just tried s-video input and that does not work either.
Thanks!
Mark
:Fuel:
strandedinnz
Re: O2 video input troubles
Unread postby strandedinnz » Sun Apr 27, 2008 4:26 pm
Is no one able to help ? :-(
I've have thought an SGI forum would be loaded with video gurus :-)
Mark
:Fuel:
strandedinnz
Unread postby strandedinnz » Sun May 18, 2008 3:58 pm
Well I tried the module in an R5200 O2 and still can't get a picture from an external video source ... I can;t believe it is toast though as if I connect the output to the input (and use a bit of the desktop as the video output) I can see the picture ....
:Fuel:
porter
Unread postby porter » Sun May 18, 2008 4:41 pm
Are the devices PAL, SECAM or NTSC?
UK and NZ use PAL. Have you got the O2 expecting that?
strandedinnz
Unread postby strandedinnz » Mon May 19, 2008 5:40 pm
Yup! not a complete novice at video ;-)
The odd thing is this .. if I have an external video source plugged in and open the video preview window I see blackness .. but if I pull the video source out and then back in again I'll get a single field/frame appear in the window ?!??!
Annoyed is not the feeling I have :-) I'm sure it's just a setting somewhere I'm not getting.
For what it's worth, I get perfectly good video from the Camera in the digital port .. just the analog stuff not working.
Mark
:Fuel:
porter
Unread postby porter » Mon May 19, 2008 6:00 pm
strandedinnz wrote:if I pull the video source out and then back in again I'll get a single field/frame appear in the window ?!??!
Can you do that 25 times a second?
strandedinnz
Unread postby strandedinnz » Mon May 19, 2008 6:30 pm
Hmmm ... maybe I should get an apprentice in .. be a good job for them :-)
Mark
:Fuel:
Unread postby recondas » Mon May 19, 2008 6:37 pm
A few thoughts <on the remote chance you haven't already had them>:
You mentioned using an Amiga and a Commodore as video sources. Have you tried a different source, perhaps a VCR or DVD?
If all your attempts have with composite ports try S-Video.
I didn't see where you specifically mentioned video capture, but you might try it at the command line to see if you get any helpful error messages <btw - what program are you using?>.
If you haven't already, take a look at "man O2Video".
porter
Unread postby porter » Mon May 19, 2008 8:07 pm
Seriously though, perhaps it's not extracting the vertical sync.
Dr. Dave
Unread postby Dr. Dave » Mon May 19, 2008 8:57 pm
if this is of any help, a while ago i was messing around with Irix 6.2 (or was it 6.3?) on an O2, the older OS was far more tolerant of sloppy sync timing than 6.5 was. Somewhere along the way, they seemed to have changed things.
Return to “SGI: Video”
