mediarecorder errors
brembs
Unread postby brembs » Fri Mar 07, 2008 7:03 am
Ok, I'm finally caving in. For the last few weeks I've been restoring our old O2. Installed system (6.5.30), software, etc. All of my problems were solved by simply searching here. What an awesome community! But now I can't find any reference to the errors I'm getting here.
So this is my first post. And I thought I could get it running all by myself, without having to ask you guys...
I'm trying to capture video from an SVideo source. And on virtually every setting mediarecorder says after recording "cannot map buffer for image conversion", even when I set it to "uncompressed".
When I switch between different formats, it often complains that it "failed to allocate image buffer".
Couldn't find any reference to these errors anywhere. Do you have any pointers what I should check? Here's my hinv:
CPU: MIPS R5000 Processor Chip Revision: 10.0
FPU: MIPS R5000 Floating Point Coprocessor Revision: 10.0
1 300 MHZ IP32 Processor
Main memory size: 832 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
Thanks a lot!
Bjoern
Re: mediarecorder errors
Unread postby hamei » Fri Mar 07, 2008 7:23 am
brembs wrote:Ok, I'm finally caving in. For the last few weeks I've been restoring our old O2. Installed system (6.5.30)...
First thing I would do is dump 6.5.30 and go back to 6.5.22 Search around here, Dr. Dave found that later versions of Irix were considerably slower on the O2. 6.5.30 doesn't really give you anything on an O2 and Dr. Dave ain't no dummy.
6.5.22 (or 6.5.21 with modifications) is the lowest configuration that will run nekoware, which is why it's a good spot to be for O2's.
brembs
Unread postby brembs » Sun Mar 09, 2008 6:05 am
Hmm, that's interesting. I'll go and get the info on how to do that, thanks!
Strangely enough I now tried some of the standard settings and then modified them to pretty much what I had been trying by hand before and now it works fine. Weird.
Anyway, I now have the problem of dropped frames, despite a very high-end VCR. Gotta check the TBC options I have it seems
Unread postby SAQ » Mon Mar 10, 2008 4:56 pm
Not to mention that it's the first merge for M and F, so you get all the f-stream goodness with the downloadable overlays.
brembs
Unread postby brembs » Tue Mar 11, 2008 4:34 am
But 6.5.30 couldn't be the cause of the errors I'm getting, could it? I'm now also trying to get mplayer to work because mediaplayer refuses to play some of the videos I've captured with mediarecorder...
Basically, MPlayer plays nothing at all of what I throw at it. Weird. Maybe there are some libraries I'm missing?
brembs
Unread postby brembs » Tue Mar 11, 2008 6:10 am
Here's acut and past of the error I'm getting with mplayer - it's always the same error, no matter what video I'm trying to play...
This one's for a divX movie (doesn't play in SGI mediaplayer):
MPlayer 1.0rc1- MIPSpro Compilers: Version 7.4.4m (C) 2000-2006 MPlayer Team
CPU: SGI MIPS
Playing /home/brembs/videos/Highlander.avi.
Cache fill: 18,36% (1540096 bytes)
AVI file format detected.
VIDEO:  [DX50]  640x360  24bpp  25,000 fps  779,1 kbps (95,1 kbyte/s)
Trying to force video codec driver family mpegpes...
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16be, 224,0 kbit/15,87% (ratio: 28000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
[AO SGI] init: Samplerate: 44100Hz Channels: Stereo Format s16be
AO: [sgi] 44100Hz 2ch s16be (2 bytes per sample)
Starting playback...
VDec: vo config request - 640 x 360 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1,78:1 - prescaling to correct movie aspect.
VO: [sgi] 640x360 => 640x360 Planar YV12
[ws] Error in display.
[ws]  Error code: 2 ( BadValue (integer parameter out of range for operation) )
[ws]  Request code: 145
[ws]  Minor code: 3
[ws]  Modules: decode_video
...and this one for a vido captured from VHS tape on the O2 (plays fine in mediaplayer, but not in mplayer):
CPU: SGI MIPS
Playing /home/brembs/videos/aggression1.avi.
Cache fill: 19,34% (1622016 bytes)
AVI_NI: No audio stream found -> no sound.
AVI: No audio stream found -> no sound.
VIDEO:  [JPEG]  768x576  24bpp  25,000 fps  29506,8 kbps (3601,9 kbyte/s)
Selected video codec: [ffmjpeg] vfm: ffmpeg (FFmpeg MJPEG decoder)
Audio: no sound
VDec: vo config request - 768 x 576 (preferred colorspace: Planar 422P)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
VDec: using Planar 422P as output csp (no 1)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: reducing / aligning filtersize 1 -> 1
SwScaler: reducing / aligning filtersize 9 -> 8
SwScaler: BICUBIC scaler, from yuv422p to yuv420p using C
SwScaler: using C scaler for horizontal scaling
SwScaler: using 1-tap C "scaler" for vertical scaling (YV12 like)
SwScaler: 768x576 -> 768x576
VO: [sgi] 768x576 => 768x576 Planar YV12
[ws]  Minor code: 3
Return to “SGI: Video”
