videoin error - couldn't open VL video
Unread postby uunix » Thu Jan 29, 2015 2:02 pm
Trying to run videoin and getting this console message:
videoin: error opening video: VL:Bad Access to the library
System is
OCTANE 4# hinv -vm
      PM20600MHZ Board: barcode MLD086     part 030-1778-001 rev  C
            IP30 Board: barcode LMF635     part 030-1467-001 rev  D
    PWR.SPPLY.ER Board: barcode AAE1140055 part 060-0035-002 rev  A
             FP1 Board: barcode MGL353     part 030-0891-003 rev  J
        XTALKPCI Board: barcode MDJ659     part 030-0952-005 rev  E
  ODY128VERSIONB Board: barcode LLG968     part 030-1611-001 rev  C
       XTALK_PCI Board: barcode MGY465     part 030-1275-004 rev  A
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 3584 Mbytes
Xbow ASIC: Revision 1.4
  Disk drive / removable media: unit 2 on SCSI controller 0: 720K/1.44M floppy
Integral SCSI controller 2: Version Fibre Channel QL2340, 33 MHz PCI
Integral SCSI controller 3: Version Fibre Channel QL2340, 33 MHz PCI
Graphics board: V12
Gigabit Ethernet: tg1, PCI slot 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 3
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 1
Dual Channel Display
        Managed (":0.0") 2560x1024
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
        Compositor port 0 attached to channel 0 nic 0x1004a768
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: SNY -19200      Monitor 2 type: VSC 12833
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (2@1280x1024_60)
        Channel 1:
         Origin = (1280,0)
chkconfig videod is on.
Drivers are installed OK.
I saw an exact posting on nekochan, but the OP fixed it themselves, I'm hoping they answer my PM
So where to start first? I'm guessing it's something silly judging by the post.
Re: videoin error - couldn't open VL video
Unread postby recondas » Thu Jan 29, 2015 4:00 pm
uunix wrote:Drivers are installed OK.
I didn't catch it in your hinv. Is there a particular video hardware option board you're trying to capture video with?
Unread postby uunix » Thu Jan 29, 2015 4:32 pm
ah.. it's not displaying XT-DIGID board.. well spotted recondas.
Unread postby recondas » Thu Jan 29, 2015 5:39 pm
uunix wrote:ah.. it's not displaying XT-DIGVID board.. well spotted recondas.
On the odd chance you don't already know, the XT-DIGVID (aka the DM2) won't work with the classic SGI (primarily analog) video tools like videoin or the underlying video daemon (videod). Instead they use SGI's later (digital) video media libraries (aka OpenML).
If you don't already have the software libraries for your DM2, you can freely download them SGI's Supportfolio site or Ian's Depot Resources page.
If a little additional background might prove helpful, this thread might be interesting: viewtopic.php?f=16&t=16727126&p=7354470&#p7354470
After you're able to get the DM2 to appear in an hinv -vm, you can try some of the tools supplied in the DM2 software, like xtdigvid_hinv or xtdigvid_confidence.
Unread postby uunix » Fri Jan 30, 2015 1:14 am
I didn't know that recondas, thanks, & thanks for the info. :-)
Return to “SGI: Video”
