Cheap composite tbc recommendation for O2 capture
rooprob
Unread postby rooprob » Sun Jun 15, 2014 1:18 am
Hi
Someone gave me a stack of VHS tapes for encoding. The VHS player provides good output, but not solid time base corrected output for the O2 not lose a frame after a few minutes.
A little research led to this link, however time has not made availability of 50buck video scaler pro devices easy to find.
http://www.unterzuber.com/TBC.html
Certainly not as cheap as mentioned on ubterzuber, at the 200$ this cbt100 appears to be the OEM for the AVT 8710
http://www.threedoubleyou.com/tbc.htm
http://www.avtoolbox.com/avt8710.shtml
Just wondering what other nekochaners have experienced at the consumer end of the video capture world.
Anyone not have use for their TBC let's PM.
New Zealand
rooprob
Re: Cheap composite tbc recommendation for O2 capture
Unread postby rooprob » Mon Jun 30, 2014 9:49 pm
Reply to myself:
The CDM-640 Videolabs Videoscaler Pro does an excellent job.
Not quite the bargain from 2004 but just completed two perfect captures in 2hrs, so that's good enough for me.
Interesting finding: occasionally the O2 will hard lock - but not! Mine has always done on capturing video, switching between an hour or so of captures, even with a different CPU and memory. I've discovered it's not _hard locked_ in the sense I understand it - catatonic, unresponsive X, mouse, and ethernet - basically no interrupt handling. The DMA for audio is still functioning, outputting to the speaker. On a hunch I flicked the input selectors on the VideoPro to attempt to stimulate the AV card video receiver and the O2 came back to life. It wasn't immediate, and took some patience. Ping and mouse came back. After that though, it locked again fairly quickly on a capture, so some kind of state is being corrupted. So a kernel deadlock tied to the video capture, and worse, one that completely inhibits X/mouse/network interrupts. C'mon IRIX. There's nothing worse than a kernel bug and no source.
So want to get into the mavb NetBSD driver for video capture, but we still need a driver for the realtime compression.
New Zealand
Unread postby vishnu » Fri Jul 04, 2014 11:26 am
That's good to know I've got a stack of VHS tapes I need to convert and I'd dearly love to use my Octane to do it. Here's a question that's possibly worthy of its own thread, does anyone have any experience with the O2 Multiport Video Processor option? Here's a Techpubs link: http://techpubs.sgi.com/library/tpl/cgi-bin/getdoc.cgi?coll=0650&db=man&fname=/usr/share/catman/p_man/cat3dm/video/mvp.z
Unread postby robespierre » Fri Jul 04, 2014 2:00 pm
that isn't an option, that's the built-in video processor of the O2.
if you want additional video ports, there was a device called the Carbon by a third party.
rooprob
Unread postby rooprob » Fri Jul 04, 2014 2:04 pm
It's my understanding that the MVP is the option I'm using. MVP being the kernel driver for the A/V or plain audio option cars
There is a completely digital card too and maybe it's the same MVP driver. Moosehead Video Port.
It's the fairly standard audio/video board with the O2cam port. I'm using composite video in and audio stereo in.
You mention Octane: do you have the personal video option? You probably know but you don't get real time compression without the dedicated MPEG compression card. Shame they didn't put ICE in more products but that was probably market positioning for you.
New Zealand
Unread postby vishnu » Fri Jul 04, 2014 3:00 pm
So you guys are saying that's a unique capability of the O2, Octanes don't have it?
rooprob
Unread postby rooprob » Fri Jul 04, 2014 11:41 pm
There was a whole line of products under the Cosmo Compress banner supporting XS through Impact for Indigo Indy Indigo2 and Octane. So those are all option cards for realtime compression with varying degrees of scarcity and price.
In that regard the O2 is the odd one out.
O2 CPU board contains two CPUs. One is whatever model system R5000 etc. the other is a R3000 derived SIMD which delivers real time image and media functions. It's only presented through the digital media libraries and AFAIK there's no official support to hand code it in MIPS assembler to make it do arbitrary things. What you have in Irix is all you get, see /var/arch/vicetre/.
They called this the ICE or VICE processor for Video Image Compression Engine. This utilised the O2's Unified Memory Architecture leading to the amazing effects not possible on the other platforms. Some say it's also the heart of the Nintendo 64 which may be true given the close ties at the time.
So yes by default it's only something O2 can give you, unless you have the various options.
Personal video on Octane for MJpeg must use the main CPU which was too slow for real time resulting very long post processing and you needed enough raw disk io to perform the uncompressed capture without dropping frames .
New Zealand
Unread postby vishnu » Sat Jul 05, 2014 11:15 am
So wait, then what the heck are these two doopies for: http://www.nekochan.net/wiki/SGI_O2#O2_Video_System
I remember there was a guy on ebay selling Octane Personal Video Option boards with instructions for getting them to work on Octane2s unfortunately I did not save a copy of the instructions...
Unread postby robespierre » Sat Jul 05, 2014 11:53 am
The AV1 and AV2 boards act as the analog side of the video I/O subsystem. If you take the covers off them, you find that there's not much inside; audio codec, amplifiers, video switchers and amps, and digital video transceivers. no custom chips.
jodys
Unread postby jodys » Sat Jul 05, 2014 12:48 pm
Actually the VICE is three seperate things: a DMA engine, the bitstream processor which is a a weirdo 16 bit custom MIPS CPU that is designed for Huffman coding/decoding, and the aforementioned R3K which is paired with a SIMD vector coprocessor, AKA the MSP. The MSP can execute a scalar and a vector instruction simultaneously, so really the VICE ought to be thought of as three additional CPUs. openGL, the imaging libraries, and the digital media libraries execute code on the VICE through a library, libvice, in Irix. I have yet to locate any headers for libvice, though. Fun fact: Irix ships with microcode for the VICE for MPEG2 encoding and decoding, but there is no support in the rest of Irix. MPEG2 was one of the major design goals for the VICE, but somehow all we get is MJPEG. Maybe the chip didn't perform as well as desired. I don't know.
:Octane2: :Indy: :O2: :O2: :O3x0: :Indigo2IMP:
Unread postby vishnu » Sat Jul 05, 2014 1:07 pm
Thanks you guys are a veritable font of information! :mrgreen:
jodys wrote:Actually the VICE is three seperate things: a DMA engine, the bitstream processor which is a a weirdo 16 bit custom MIPS CPU that is designed for Huffman coding/decoding, and the aforementioned R3K which is paired with a SIMD vector coprocessor, AKA the MSP. The MSP can execute a scalar and a vector instruction simultaneously, so really the VICE ought to be thought of as three additional CPUs. openGL, the imaging libraries, and the digital media libraries execute code on the VICE through a library, libvice, in Irix. I have yet to locate any headers for libvice, though. Fun fact: Irix ships with microcode for the VICE for MPEG2 encoding and decoding, but there is no support in the rest of Irix. MPEG2 was one of the major design goals for the VICE, but somehow all we get is MJPEG. Maybe the chip didn't perform as well as desired. I don't know.
Hmmmm, that's interesting, so none of that intended functionality made it into the O2+ version either? And then they left it all out for the Octane, Fuel and Tezro? :cry:
rooprob
Unread postby rooprob » Sat Jul 05, 2014 2:30 pm
@jodys Cool. Good knowledge. I did know about the BSP and MSP but only from the old Linux source.i believe crime can also take over the from the main CPU. Any idea what the various file types are all about in the var arch vice directory.
To Vishnu comment not that the demise of sgi isn't already well covered I believe the SGI descendant of the O2 was the Visual Workstation. The O2+ was a pretty cynical relaunch of the original with minimal engineering effort.
New Zealand
Unread postby vishnu » Sat Jul 05, 2014 2:45 pm
rooprob wrote:To Vishnu comment not that the demise of sgi isn't already well covered I believe the SGI descendant of the O2 was the Visual Workstation. The O2+ was a pretty cynical relaunch of the original with minimal engineering effort.
Oh well but at least the O2+ had the R12000 400MHz version, which people must still find to be pretty useful because you sure don't see them for sale anywhere...
Unread postby robespierre » Sat Jul 05, 2014 4:18 pm
rooprob wrote:@jodys Cool. Good knowledge. I did know about the BSP and MSP but only from the old Linux source.i believe crime can also take over the from the main CPU. Any idea what the various file types are all about in the var arch vice directory.
the Crime chip (CRM) is like the "northbridge" of the O2. it accepts requests from the CPU and the other I/O chips and buffers them to the memory. It also contains the OpenGL accelerator component, unimaginatively called the "Rendering Engine", which is like the Indy's XL graphics (no geometry engine).
the VICE chip sits on the same bus as the CPU (SysAD bus), which limits its usefulness somewhat, since they both share the same path to main memory. Furthermore, they are not cache-coherent with one another.
Unread postby hamei » Sat Jul 05, 2014 7:09 pm
vishnu wrote:I remember there was a guy on ebay selling Octane Personal Video Option boards with instructions for getting them to work on Octane2s ...
I thought the Personal Video only worked on Mardi Gras graphics ? I know it has those three ribbon cable connections to the MXE, which don't exist on VPro ... the Octane Compression card supposedly does work with VPro, tho. Have one but never installed it so I can't say from personal experience ...
Return to “SGI: Video”
