Adobe Premier 4.2 on Octane/V12
Jack Luminous
Unread postby Jack Luminous » Thu May 29, 2014 6:27 am
So, has someone successfully run Premiere on a VPro equipped Octane ? Is there some known trick or should I let it go already ? :?:
Re: Adobe Premier 4.2 on Octane/V12
Unread postby hamei » Thu May 29, 2014 6:29 am
Jack Luminous wrote:So, has someone successfully run Premiere on a VPro equipped Octane ? Is there some known trick or should I let it go already ? :?:
People were bitching about it when it was brand new.
It doesn't seem to have improved :D
Jack Luminous
Unread postby Jack Luminous » Thu May 29, 2014 7:31 am
LOL thanks for your straight-to-the-point reply. :D
Unread postby foetz » Fri May 30, 2014 9:20 am
indeed, premiere was probably the worst of all video programs for irix. and that means something :P
Unread postby vishnu » Sat May 31, 2014 6:52 pm
According to Ian in this post it works with non-VPro, or, at least with MXE. If I recall correctly, if you launch it it fires up a couple of processes and then hangs forever, never even bringing up its splash screen. You have to manually kill the processes. Unless you don't mind them sitting there taking up memory until your next reboot. ;)
Return to “SGI: Video”
