diegel wrote:
In my experience -vo gl2 is a workaround for this problem.
Oooh. Nice, thanks ... fixed about half of my problem videos ...
What is the reasoning behind the various output options ? I've been using vo=sgi:textures:softcs and that's worked well on most videos. Is OpenGL
always better if you have that option ? Since SGI does OpenGL in hardware, would you think it should normally be a better choice for us ?
Edit: Okay le, did a little testing. Thanks for the pointer to gl2, I had lazily assumed that once you found settings that worked, they would work across the board. So, for posterity ...
With the nekochan version of Mplayer, there are several output options. You can set defaults in $home/.mplayer/config. I usually watch a video by just dragging the file icon over the mplayer icon. This is a case where the workplace shell would be great - make three or four copies of the mplayer object and change the parameters of each one. Viola (don't call me Shirley), you can easily run different videos with different settings. MaxxDesktop with Porter's SOM would be the best desktop ever for Loonix. Oh well.
Anyhow, I ran the same video through the five or six useful ones : < mplayer -vo help > (turning a video into tiffs was not what I want to do at the moment, but might be worth looking into for screenshots - like when Michael Douglas lost the purse going over the falls, but there it was in the next scene and you want to pick up the frame that you know shows it flying through the air).
vo = sgi is opengl, seems the sharpest and least dropped frames
vo=gl is opengl, I can't see much difference but may as well go with the sgi-optimized version
vo=gl2 is not as sharp but as diegel points out,
other output options might solve problems with display of some videosvo=sdl is not as good, in fact I saw a lot of dropped frames on several videos. But again, it
may work in certain instances. Plus it's good for testing neko_sdl
vo=aa is kind of interesting but not very useful, except for a special effect sometimes. Try it, it's kind of a trip
The lesson, thanks to Mr Diegel, is to not get lazy and assume that your output options are the best for every video. If there are display problems, one of the other choices may solve the problem
for that video.
