DM2 white VBOB cable
Axatax
Unread postby Axatax » Sat Apr 23, 2011 12:45 am
Is this necessary? I have two back cables but don't want to fry this HW.
:Octane2: Dual R14K@600MHz, 2GB RAM, V12, 1x72GB HDD
:O2: R10K@175MHz, 512MB RAM, 1x72GB HDD
:Cube: 68040@33MHz, 128MB RAM, NeXTdimension 32MB, 2x 4.3GB HDD
...And lots of other UNIX-like systems for which there is no icon.
Re: DM2 white VBOB cable
Unread postby recondas » Sat Apr 23, 2011 4:59 am
The so far unsubstantiated rumor is that the color difference was only cosmetic - to prevent unintentional cable-crossover during installation. Believe at least a few have tried two black cables, so maybe they'll speak up to substantiate the rumor.
In the mean time you could do a great service to the world of SGI collectors by metering the pin out of one of your black cables: viewtopic.php?f=3&t=16724990
zski128
Unread postby zski128 » Sat Apr 23, 2011 5:43 am
I tried two black cables and it appeared to work, although I did not test very deeply. I could 'see' the VBOB from my Octane. Consider yourself lucky that you even have the cables! ;)
:O2000: :Indigo: :Indy: x2 :Octane: :O2: :Fuel:WIP :1600SW:x2
tomvos
Unread postby tomvos » Sat Apr 23, 2011 12:43 pm
My Octane2 has a VBOB connected with two black LVDS cables. The VBOB is recognized by a well known application and flashing a new firmware worked without a problem.
I did not had any chance to use HD-SDI, so I can't say for sure that the whole data path works with two black cables as it is intended to do … but at least your're unlikely to fry your VBOB or DM2/3 by using two black cables. :D
Return to “SGI: Video”
