ANNOUNCE: pjcap for O2
Re: ANNOUNCE: pjcap for O2
Unread postby nekonoko » Thu Jul 22, 2010 8:10 pm
I've attached the version I archived; not sure if it is the most recent.
pjcap.tar.gz
(14.1 KiB) Downloaded 152 times
hazelden
Unread postby hazelden » Sat Jul 24, 2010 1:00 pm
Thanks! I really appreciate getting a copy of pjcap.
Regards,
Andrew Hazelden
Andrew Hazelden, VFX Artist
Personal Blog: www.AndrewHazelden.com
:O2: SGI O2, 195 MHz R10K, 320 MB ram, AV1 Video i/o card, 36GB HD
vetal
Unread postby vetal » Mon Sep 06, 2010 5:19 pm
Is it possible to capture raw video and sound simultaneously?
:O2: SGI O2, 180 MHz R5K, 256 MB RAM, AV1 Video I/O card
hazelden
Unread postby hazelden » Wed Oct 20, 2010 7:32 pm
vetal wrote:Is it possible to capture raw video and sound simultaneously?
Looking over the command line options for pjcap it looks like the current version only records video. You will have to record and sync up the audio separately from the video.
Copyright (c) 2010 by Phil Jensen (kshcsuf@gmail.com)
All rights reserved.
Usage: pjcap [args]
        -f      filename
        -s      capture via S-video
        -c      capture via composite
        -n x    frames to capture
        -y      YUV 4:2:2 video (16-bit, default, VL_PACKING_YVYU_422_8)
        -r      RGB video (32-bit, very I/O intensive, VL_PACKING_ABGR_8)
        -S      square pixels (640x480, default, VL_TIMING_525_SQ_PIX)
        -N      non-square pixels (720x486, VL_TIMING_525_CCIR601)
        -d      debugging mode
        -O      disable optimizations
Example:
        ./pjcap -f ./testfile.yuv -s -y -n 500
This will capture to /testfile.yuv using the S-video port
in a YUV 4:2:2 colorspace for 500 frames.
necron2600
Unread postby necron2600 » Fri Nov 06, 2015 8:21 am
Anyone know where to find a copy/link to this file?
Thanks
-Kevin
Unread postby dexter1 » Fri Nov 06, 2015 8:44 am
Go up a few posts, there's a link provided by Nekonoko
necron2600
Unread postby necron2600 » Sat Nov 07, 2015 3:52 pm
Ah.. my bad. ;) I see the link now.
Thanks!
Return to “SGI: Video”
