Recording lengths with Octane Compression...
Unread postby bigD » Mon Oct 26, 2009 4:54 pm
Sigh...I'm sure you guys are sick of my stupid Octane Compression questions! :) But here's another one...
I've been successfully capturing 5-10 minute clips without trouble, but last night I tried to record a much longer clip, and without fail it'll get about 15-20 minutes through, and then start dropping every frame from then on. This will happen regardless of the bit rate - I've tried 30Mbit/sec down to 10Mbit/sec, and it always seems to get about 25-35,000 frames through (with no dropped frames) - then drop every single one until I stop dmrecord with a control-c.
I've looked at what's going on with the system once it begins dropping frames, and I can't see anything amiss. The processors are still 98% or so free, plenty of available memory, with no unusual processes happening in the background. I have two 73GB 10K hard drives installed, and it does this when recording to either. The dmrecord syntax I'm using is
dmrecord -p video,device=impact,comp=jpeg,engine=impact,brate=30000000 -p audio
Any ideas?
:Onyx2: :Indigo2: :O3x0:
Re: Recording lengths with Octane Compression...
Unread postby Zerolapse » Mon Jan 04, 2010 11:46 am
How is your cabling? I was having similar issues recording from my cable box until I finally bought some new a/v cables, and now all is well.
The current fleet.
Return to “SGI: Video”
