What software uses the firewire on a Fuel ?
strandedinnz
Unread postby strandedinnz » Wed Sep 09, 2009 6:10 am
Hi there,
I've a firewire board in my Fuel .. how do I make use of it ?
I want to both import and export video via it .. but I don't know what commands under IRIX would do that.
Any pointers ... I quite happily RTFM if I know which manual to read :-)
Thanks
Mark
:Fuel:
Re: What software uses the firewire on a Fuel ?
Unread postby recondas » Wed Sep 09, 2009 4:59 pm
I queried "firewire" and "fuel" and found these <not too promising> threads:
viewtopic.php?f=3&t=16719300&
Unfortunately it looks like nothing much has changed from December '08:
viewtopic.php?f=16&t=16719650&
In December 2008 you wrote:
strandedinnz wrote:I suppose the next question is .... how do I capture video from a firewire device ?
jan-jaap wrote:I'm afraid the short answer is 'you don't'.
The search brought back a few more, but unfortunately I think those two pretty much sum up the current state of the fuel-firewire-video situation.
Unread postby hamei » Thu Sep 10, 2009 8:50 am
strandedinnz wrote:Any pointers ...
Pick up a Canopus ADVC 55. Then we'd confirm that none of the supported firewire video devices work.
Return to “SGI: Video”
