I want to make a QuickTime video from a sequence of JPEGs
porter
Unread postby porter » Sat May 16, 2009 5:05 pm
But don't want have to buy QuickTime Pro to do so.
Back in the early days of QuickTime I'm sure you could make movie without the extra Pro package. When was that? How is/was it done?
Moderator Edit: Moved from the Apple Forum to the SGI: Video Forum since the solution involved IRIX. <recondas>
pentium
Re: I want to make a QuickTime video from a sequence of JPEGs
Unread postby pentium » Sat May 16, 2009 5:24 pm
I'll have to double check but I think way, way back when Avid Videoshop was still being bundled with the Apple Video Kit you were able to do it.
Unread postby recondas » Sat May 16, 2009 8:43 pm
How about using IRIX?
makemovie(1)
makemovie - make a movie from movie, image, and audio files....
You can output the results in several QT formats:
Choices for the QuickTime movie format are "qt_anim" (QuickTime Animation), "qt_video" (QuickTime Video), "qt_cvid" (Compact Video), "jpeg", "huffyuv" (Huffman Lossless), and "none".
porter
Unread postby porter » Sun May 17, 2009 12:17 am
Excellent, just what I wanted, my little Indy struggled with the 124 jpegs but got there in the end!
Thanks alot, indeed!
tomo
Unread postby tomo » Sun May 17, 2009 12:26 am
Yeah, new usefull command :)
Another question - is there a command/ shell program witch creates video from multiple composition files? Like one file for background another for rendered contents?
http://www.tomosgi.co.cc
PymbleSoftware
Unread postby PymbleSoftware » Sun May 17, 2009 4:10 am
tomo wrote:Yeah, new usefull command :)
Its called shake.
Regan
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Unread postby recondas » Sun May 17, 2009 8:35 am
porter wrote:Thanks alot, indeed!
You're welcome!
tomo
Unread postby tomo » Sun May 17, 2009 9:16 am
Its called shake.
Regan
I'm using shake currently - but it is like killing flys with hammer. My tree in shake contents only these objects: 2xfile_in, layer and file out. Before shake I'v used gimp - but I must manually paste composited content to background image for every frame and then save to another file.
porter
Unread postby porter » Sun May 17, 2009 1:46 pm
recondas wrote:makemovie(1)
Just like Dire Straits. :)
tomo
Unread postby tomo » Sun May 17, 2009 9:40 pm
eMGee wrote:
tomo wrote:I'm using shake currently - but it is like killing flys with hammer. My tree in shake contents only these objects: 2xfile_in, layer and file out. Before shake I'v used gimp - but I must manually paste composited content to background image for every frame and then save to another file.
You mean in the regard that it only pays off going through the trouble of building a composite for more complex setups and operations? Because Shake itself sure is an extremely light-weight program for something as powerful as it. I don't know how well it runs on an O2, like yours, but it flies on my machine.
Yes shake is fine at O2 as mine is. But I work "only" with PAL resolutions. I'v mean that it could be far more faster (if sutch program exists) to do it like this:
./composite frame_background.#.rgb frame_rendered_contents.#.rgb -o composited_output.#.rgb
it seems mutch more faster then running shake, add nodes and then render it out... Of course if I want color manipulation ower layers or add some effects, then Shake is really good choice.
bplaa.yai
Unread postby bplaa.yai » Mon May 18, 2009 12:31 am
tomo wrote:Yes shake is fine at O2 as mine is. But I work "only" with PAL resolutions. I'v mean that it could be far more faster (if sutch program exists) to do it like this:
I'm pretty sure Image Magick would do a great job at it. Relevant examples here.
:Onyx2: :O2: :O3x0: :O3x0:
tomo
Unread postby tomo » Mon May 18, 2009 7:50 am
Thanks! This is something what I'v mean.
hazelden
Unread postby hazelden » Thu Nov 04, 2010 5:43 am
Shake can be run from the terminal and used to perform image manipulation and format conversion. You can even make an image sequence into a QuickTime movie.
Here are a few examples of commands you could use from the terrminal:
Format conversion ( -t 1-5 means to load from frame 1 to frame 5):
shake bg.@.iff -fileout frame.@.jpg -t 1-5
Format conversion with frame padding (leading zeros) on output:
shake bg.@.iff -fileout frame.#.jpg -t 1-5
Shake Composite Over in Viewer:
shake fg.@.iff -over bg.@.iff -t 1-25
Shake Composite Over Then Load Tree in GUI:
shake fg.@.iff -over bg.@.iff -t 1-25 -gui
Composite Over Save Image Sequence: (-fileout can be written as -fo)
shake fg.@.iff -over bg.@.iff -fileout comp.@.jpg -t 1-5
shake fg.@.iff -over bg.@.iff -fo comp.@.jpg -t 1-25
Comp Image Sequence and Save QuickTime Movie:
shake fg.@.iff -over bg.@.iff -fo comp.mov -t 1-25
Andrew Hazelden, VFX Artist
Personal Blog: www.AndrewHazelden.com
:O2: SGI O2, 195 MHz R10K, 320 MB ram, AV1 Video i/o card, 36GB HD
squeen
Unread postby squeen » Fri Nov 12, 2010 4:02 am
A FLOSS option is ffmpeg. Its fast, supports a ton of codecs, has few dependencies and is even in Nekoware.
Return to “SGI: Video”
