Cables for DM3 to VBOB
zski128
Unread postby zski128 » Tue May 12, 2009 9:16 am
Does anyone know what the difference is between the cables below? I can only find the top one so far. Can I just use two of 018-0946-001?
See thread: viewtopic.php?f=5&t=16720804
Part numbers:
018-0946-001 CABLE ASSY LVDS 26P M 5M FE $116
018-0985-001 CABLE ASSY LVDS 26P M 5M WHT/WHT FE $237
:O2000: :Indigo: :Indy: x2 :Octane: :O2: :Fuel:WIP :1600SW:x2
zski128
Re: Cables for DM3 to VBOB
Unread postby zski128 » Wed Jul 01, 2009 7:27 pm
OK, was able only to get 2 of the black cables: 018-0946-001. Now how do I test this thing? My Octane sees the DM3 card and the VBOB (p/n: 013-2746-004 rev D) has a yellowish light on the fron SGI logo. I don't see any green LEDs on the rear. Are there any test commands in IRIX?
Thanks!
Rich
zski128
Unread postby zski128 » Sat Jul 04, 2009 6:52 am
Well I did find some commands, vbob_config, vbob_flash etc. I ran a vbob_config and it seemed to work, I guess, at least it did not error out saying it could not see it.
The only concerning thing is the color of the light on the SGI logo, its a yellowish color. I though I remembered seeing pictures of one in google image search with a white colored light...
Anyone on here know what the color should or should not be? Could not seem to find anything on the web or in the docs on this...
Unread postby SAQ » Sun Jul 05, 2009 6:49 pm
zski128 wrote:The only concerning thing is the color of the light on the SGI logo, its a yellowish color. I though I remembered seeing pictures of one in google image search with a white colored light...
I wouldn't worry about it. Phosphors can change a bit, so it might have gone yellow.
Return to “SGI: Video”
