Horsepower required to play H.264 video?
ritchan
Unread postby ritchan » Sun Sep 21, 2008 7:37 am
I'm not expecting smooth 720p playback on SGI MIPS machines, but I still do want something fast enough to play my H.264 anime episodes, otherwise it wouldn't be that practical. What kind of CPU/speed would I need to play a 704x480 H.264 video using mplayer? What about slightly larger sizes (848x480, 1024x576)? Does video output performance depend very much on texturing hardware, or can mplayer use an overlay?
Originally Posted by Tommie
Please delete your post. It is an insult to all the hard work society has put into making you an intelligent being.
Like somebody at AMD said about a decade ago: Benchmarking is like sex. Everybody brags about it, everybody loves doing it and nobody can agree on performance.
Re: Horsepower required to play H.264 video?
Unread postby nekonoko » Sun Sep 21, 2008 11:43 am
That's one of things I'm hoping dexter1 can eventually optimize in mplayer if he has time. Right now, it's basically impossible to play back H.264 anime smoothly even at 800MHz.
D-EJ915
Unread postby D-EJ915 » Sun Sep 21, 2008 11:59 am
h264 MKVs are even slow on my 2.2GHz opteron, I really hate that codec/wrapper :/
ritchan
Unread postby ritchan » Mon Sep 22, 2008 6:15 am
nekoneko, what exactly is the problem with mplayer's code? Optimized for 32bit machines perhaps?
D-EJ915: impossible. Stop using -vo x11 and use -vo xv, xvidix. My Athlon XP 1800+ can play 720p just fine.
Unread postby nekonoko » Mon Sep 22, 2008 8:10 am
ritchan wrote:nekoneko, what exactly is the problem with mplayer's code? Optimized for 32bit machines perhaps?
It's just not optimized for MIPS. Dexter1 did extensive mplayer MIPS optimization before H.264 was added a few years ago which made an enormous difference, but the path for H.264 isn't similarly optimized at this point in time.
Unread postby dexter1 » Mon Mar 09, 2009 1:59 am
I've briefly looked into this, since this codec is becoming increasingly popular among recent Blu-Ray formats and small handheld devices because of the higher quality and lower stream bandwidth requirements than conventional mpeg streams.
This codec is a real CPU hog. It looks to be an upgrade over the Sorensen codec which is used in early Quicktime designs in Mplayer from 2005. I did do some optimisations on this codec when i was busy with simple_idct.c for the mpeg codec, but the codec algorithm has much more branching and much finer idct blocking (4x4 instead of 8x8) so i only got a speedup of 5% or so.
To make a significant change in processing speed, i believe we have to resort to Assembly on the R10k/R12k and you probably need a second processor to handle the brunt of the remaining workload, like color conversion and loading/storing imaging, audio and openGL stuff.
Guess what i am reading at the moment? Yep: MIPS R10000 Microprocessor User Manual
This looks to be fairly complicated, because of the different design compared to X86 CPU's with mmx. If you browse ffmpeg source for H.264, you will see that this codec has extensive mmx/sse Assembly code for x86 architechture, so even there people had to resort to Assembly to speed things up.
Anyway, i will browse a bit and form some ideas.
ritchan
Unread postby ritchan » Mon Mar 09, 2009 4:20 am
Yay. Well, I might get a VPro in the future to speed up video output, so don't you dare give up on this halfway! I've already got two TRAMs on the way...
tomo
Unread postby tomo » Mon Mar 09, 2009 11:42 am
Often in my case is mutch better/ faster to run mplayer in this way:
npri -r 100 -s RR mplayer something.avi
This setting may cause (if video is too big to play smooth) total stop for other applications, even mouse pointer can stop responding.
Dexter - thanks for fantastic optimizations made to mplayer, I'm using it often so any even small improvement is welcome :)
http://www.tomosgi.co.cc
Return to “SGI: Video”
