Miro DC30 compared to O2 AV1 video
bjames
Unread postby bjames » Mon Jan 07, 2008 11:19 am
Just wondering how the O2 (AV-1) video quality would compare to a Miro (Pinnacle) DC-30 board on a wintel machine, specifically image quality during capture and printing to tape. I used to use the DC-30 with Premier 5.0 and was reasonally satisfied with the performance and quality for what I was using it for. Below is a comparison of the my old wintel system and my O2 that I dont have setup yet. Can anyone provide their opinion on how the two machines may compare in performance? Just wondering if I sould look at upgrading to the digital video option.
Miro DC-30 Machine
Win NT4.0, SP2
Dual P2 350mhz
512 mb ram
single IDE hard drive UDMA-66 (6 gig)
O2 R10000 250MHZ
512mb RAM
AV Option (AV-1 analog)
18 gig 10K RPM drive
(6) SGI 4 gig external disk array - Raid 0 for video
:O2: :Octane: :1600SW:
fu
Re: Miro DC30 compared to O2 AV1 video
Unread postby fu » Tue Jan 08, 2008 11:10 am
i remember wondering about the o2's video capabilities when i first got it...
it looks so sexy, was made for video and your fingers are itching to see what gives...
i guess every new o2 owner wants some quick/rough comparison between the o2 and a mac or pc or whatever but its meaningless
o2s were being used for video work by some broadcasters/posthouses etc but that's where it ends...
(o2 was not made for the average off the self mumbojumbo hw/sw)
bjames wrote:Just wondering how the O2 (AV-1) video quality would compare to a Miro (Pinnacle) DC-30 board on a wintel machine, specifically image quality during capture and printing to tape...
(i've never used a pc set up/pinnacle hw myself) i did some quick+dirty captures with the o2's AV-1 and it was fine (as far as s-video goes)
if just want to play around why don't u give the AV-1 a try and see for yourself?
if u want to do some work that matters, leave the o2 where it is and work with a recent mac setup
bjames wrote:...Just wondering if I sould look at upgrading to the digital video option.
hex!
dig.vid option for the o2 talks SDI which is professional stuff, nothing to do with s-video
unless you already have decent sdi back-end ready to work under irix just don't bother
oh and btw: the true cost of any aqusition device is how much the post costs.
oh and btw2: take a look @ O2 HW Aggregator faq #6 and you'll find a link to C. Pirazzi's Lurker's Guide to Video (reading it is essential)
jdboyd
Unread postby jdboyd » Tue Jan 08, 2008 2:56 pm
bjames wrote:Just wondering how the O2 (AV-1) video quality would compare to a Miro (Pinnacle) DC-30 board on a wintel machine, specifically image quality during capture and printing to tape. I used to use the DC-30 with Premier 5.0 and was reasonally satisfied with the performance and quality for what I was using it for. Below is a comparison of the my old wintel system and my O2 that I dont have setup yet. Can anyone provide their opinion on how the two machines may compare in performance? Just wondering if I sould look at upgrading to the digital video option.
Miro DC-30 Machine
Win NT4.0, SP2
Dual P2 350mhz
512 mb ram
O2 R10000 250MHZ
512mb RAM
Quality wise, I don't know that one is vastly better than the other. Unless you have a specific need for SDI, I wouldn't upgrade to the digital video option. Even then, I'd rather wait to find a Miranda VIVO.
However, I thought that R10k O2s were bad for video (some clash that was fixed in the R12ks and never a problem in the R5ks, R5.2Ks or R7ks).
Also, should you decide to actually use the O2, I would replace the external array with a single relatively new 18 or 36 gig drive in an external case. Single SCSI drives that will do 35MB/s aren't that hard to come by cheaply.
bjames
Unread postby bjames » Tue Jan 08, 2008 3:21 pm
Isnt that 35mb/sec burst rate? Right now I have 6 of the PG4 SGI stripped as one volumn that will do uncompressed video without dropping a frame aprox 27mb/sec sustained. Becuase I will be working with compressed video, I shouldnt need anything near that data rate. 12mb/sec sustained should be fine using 3 or 4 of the PG4 drives.
I didnt know that the R10K processor had issues with video. Probably best to upgrade to an R12K 300 mhz as the proc is still somewhat inexpensive compared to going with a 400mhz or RM7K with a new mother board.
Unread postby hamei » Tue Jan 08, 2008 7:46 pm
bjames wrote:...going with a 400mhz or RM7K with a new mother board.
You don't need a new mainboard. They are all the same (or close enough for horseshoes.)
jdboyd
Unread postby jdboyd » Tue Jan 08, 2008 9:26 pm
bjames wrote:Isnt that 35mb/sec burst rate? Right now I have 6 of the PG4 SGI stripped as one volumn that will do uncompressed video without dropping a frame aprox 27mb/sec sustained. Becuase I will be working with compressed video, I shouldnt need anything near that data rate. 12mb/sec sustained should be fine using 3 or 4 of the PG4 drives.
The 35mb/sec was a measured rate, not a manufactors spec for burst rate.
The only thing I have against using compressed is that you only get one video stream. I would like to be able to have multiple video streams going at once. Striping 2 of those disks (I'm sorry, I'd post the model, but it isn't convienient for me to look at the drive in question) on 2 busses is just about perfect for that.
bjames
Unread postby bjames » Wed Jan 09, 2008 8:39 am
I have always thought the RM5200 / RM7000 required a different board than the R10K and R12K. So does this mean I can drop in a RM7000 processor to replace my R10K 200mhz?
bjames
Unread postby bjames » Wed Jan 09, 2008 8:40 am
Are these 10K or 15K rpm drives? My O2 has a 18gig 10K RPM system drive. I think the PG4 drives are 7200 RPM each.
jdboyd
Unread postby jdboyd » Wed Jan 09, 2008 10:59 am
bjames wrote:Are these 10K or 15K rpm drives? My O2 has a 18gig 10K RPM system drive. I think the PG4 drives are 7200 RPM each.
10,000 RPM. The drives are U160 drives.
GIJoe
Unread postby GIJoe » Wed Jan 09, 2008 11:45 am
i think the o2 analog video is a bit better than the DC30 - used to have both back in the day and did some comparisons. the o2 has quite the edge over the dc30 for the software definitely - it comes with gui and commandline tools that work nicely whereas the dc30 was kinda hacked into premiere, for me never worked reliably and support soon vanished and stayed limited to very few releases. the drawback with the o2 is the slow system itself, encoding times can be enourmous.
just the recommendation to not invest a lot into the system if you are hoping to make it useful. it's just way outdated and doesn't play well with recent tools on other platforms. been there, done that and all. it's been 11 years of technological advance since the o2 video and dc30 were considered prosumer level equipment.
bjames
Unread postby bjames » Wed Jan 09, 2008 2:39 pm
GIJoe wrote:i think the o2 analog video is a bit better than the DC30 - used to have both back in the day and did some comparisons. the o2 has quite the edge over the dc30 for the software definitely - it comes with gui and commandline tools that work nicely whereas the dc30 was kinda hacked into premiere, for me never worked reliably and support soon vanished and stayed limited to very few releases. the drawback with the o2 is the slow system itself, encoding times can be enourmous.
I have to admit that the only system I have ever regretted selling is my old Miro DC30 / premier 5.0 system. I found it to be a pretty good for what I was using it for. I have a lot of old super 8 film reels that I would like to transfer edit and add soundtrack. Now that I have the O2 with video, premier and six PG4 SGI RAID It got me think, maybe I can use this as my Premier station (replacing the old) - hoping that it will perform at least a good as my old 300mhz P2 system.
GIJoe
Unread postby GIJoe » Thu Jan 10, 2008 1:07 pm
it's premiere 4.2 in crash-edition tho, running on the least supported platform. don't expect too much. a mac mini intel with one of these firewire-video converter thingies with analog i/o will probably take a day to edit and encode what your o2 will take a week for. ;)
jdboyd
Unread postby jdboyd » Thu Jan 10, 2008 1:54 pm
GIJoe wrote:it's premiere 4.2 in crash-edition tho, running on the least supported platform. don't expect too much. a mac mini intel with one of these firewire-video converter thingies with analog i/o will probably take a day to edit and encode what your o2 will take a week for. ;)
Of course, who says you have to encode on the same machine you edit on?
Unread postby hamei » Fri Jan 11, 2008 4:37 am
bjames wrote: So does this mean I can drop in a RM7000 processor to replace my R10K 200mhz?
Yes, but you need a couple of parts. The R10/R12 cpu card sits farther off the mainboard so you need different connectors and maybe standoffs. There's an R-5 350 around here for a tad over a hundred $$ but maybe that's too much ?
Btw, you have an R10k-200 ? or 195 mhz ? People have overclocked the r5 is why I ask ... otherwise, you're liable to get people confused between the r5-200 if you call the 195 mhz r10k cpu a 200.
jdboyd
Unread postby jdboyd » Fri Jan 11, 2008 8:03 am
Wait, where is there a R5000 350 for a little over $100?
Return to “SGI: Video”
