It is currently Thu May 23, 2013 5:44 pm
Post new topic Reply to topic  [ 6 posts ]
Unread postPosted: Fri Jul 07, 2006 5:07 am
Hello all,
Could anyone shed some light on the possibility of capturing standard definiton DigiBeta with full audio on a VW 230? What SDI capture card would you recommend (may also be an old one that is no longer manufactured)? Do these cards come with a capture application and a plug-in or do you need a dedicated video app to capture?
 Post subject:
Unread postPosted: Sat Aug 12, 2006 12:15 pm
Hi,
I suggest the Blackmagic Design Decklink card.
Very good card family, 32bit pci version available. These cards come with lots of plugins and capture apps. Check the manufacturer's web site.
 Post subject:
Unread postPosted: Tue Aug 15, 2006 8:29 am
I looked at the Decklink cards but on their website it states that "Windows™ PC's must have 64-bit PCI or PCI-X slots" (which the VW 230 does not have).
 Post subject:
Unread postPosted: Wed Aug 16, 2006 1:10 pm
The whole SD line of Decklink series (Standard/SP/PRO/Extreme) available in 32 bit PCI bus version.
 Post subject:
Unread postPosted: Fri Aug 18, 2006 1:19 am
I will enquire with them. Do you know anyone who is selling one of these cards used?
 Post subject:
Unread postPosted: Wed Aug 23, 2006 12:12 pm
Personally don't, but on ebay this cards are frequent.
