It is currently Mon May 20, 2013 6:32 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: mips pro compiler
Unread postPosted: Sat Jun 28, 2003 6:42 am
What would be the lowest acceptable verson of the sgi mips compiler to run under Irix 6.5.17? And would I need additional Irix base software and or libs in order to install it, or would it install "as is"?
 Post subject:
Unread postPosted: Sat Jun 28, 2003 7:59 am
Im using 7.3 right now. there is many bug but if you have acces to update
its fine. Also Mipspro is included with a standard Irix dist (I think) you only need dev lib foundation(2 cd).
 Post subject:
Unread postPosted: Sat Jun 28, 2003 11:25 am
With Irix 6.5.x the MipsPro back ends are there (headers/linkers/etc) but the front end compilers are not. And the back ends are only installed if you installed them from the Development Libraries and Development Foundations CDs in the 6.5.x software package. I know that 6.5.8 (The full dist) had the MipsPro 7.2.1 backends, so they needed to be updated in order to install the 7.3 version of MipsPro.
WolfLord - :4D70G: :Octane2:
 Post subject:
Unread postPosted: Sat Jun 28, 2003 11:07 pm
MipsPro 7.3 is "nag-but-compile", right? Or was that 7.2.x?
 Post subject:
Unread postPosted: Sun Jun 29, 2003 2:21 am
All versions I've ever used including 7.3 throw up the standard warning but still compile anyway.
I dunno if this has changed in more recent versions.
 Post subject:
Unread postPosted: Sun Jun 29, 2003 3:31 am
I think this do not work with CC.
 Post subject:
Unread postPosted: Sun Jun 29, 2003 5:25 am
Supposedly in 7.4 they won't compile without a liscense file. I cannot confirm this however
 Post subject:
Unread postPosted: Tue Jul 01, 2003 6:20 am
So, if I purchased a version of the MIPSpro C compiler off ebay, I shouldn't have any extra software/license requirments, right? :?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 11223&rd=1
 Post subject:
Unread postPosted: Tue Jul 01, 2003 7:18 am
You'll atleast need the Development Foundation 1.2 cd as well in order to use the MipsPro 7.3 compilers.
 Post subject:
Unread postPosted: Tue Jul 01, 2003 7:31 am
Alright then. I should have at least that installed, but I'll check once I get home. This'll be listed under software manager as "Development Foundation", correct?
 Post subject:
Unread postPosted: Tue Jul 01, 2003 7:45 am
You probaly DON'T have it installed unless you have the Development Foundations 1.2 for IRIX 6.5 cd...it's not the one thats included with a full 6.5 install set(from my experiance anyway). An easy way to check is to just do a cc -version on the command line and see what shows. The 1.1 version of the development foundations will show 7.2.1 or something.
 Post subject:
Unread postPosted: Wed Jul 02, 2003 12:02 am
[quote="semi-fly"]So, if I purchased a version of the MIPSpro C compiler off ebay, I shouldn't have any extra software/license requirments, right? :?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 11223&rd=1[/quote]
That won't do you any good since this is only the C compiler. What you really want is the C++ compiler. Which you incidentally can get for free when buying some stuff of Ian at http://www.13w3.com. Also, there is a license floating around in you-know-where...
 Post subject:
Unread postPosted: Wed Jul 02, 2003 5:15 am
Hmm, this just gets more and more confusing. I'll think I'll stick with GCC for now.
 Post subject:
Unread postPosted: Wed Jul 02, 2003 7:04 am
No, it's actually quite simple...in summary:
For mipspro 7.3(any compiler), you need the Dev. Foundation 1.2 CD aswell as the compiler cd, eg. MipsPro C/C++/F77/F90.
With regard to you "really" wanting the C++ compiler...do you compile any C++ code? If you don't than just the C compiler cd is fine. So I don't see how the C compiler cd "won't do you any good".
GCC is fine for most things, but some software just won't compile with GCC on irix machines...so it can be usefull to have a MipsPro compiler around as well.
You best bet is to wait for a full 7.3 compiler set to come up for auction..then you'll have what you need. I went thru the problems of just getting the C compiler cd for 7.3 with a batch of older 7.2.1 cd for cheap, and then couldn't install 7.3 because I didn't have the right version of the Dev. Foundations.
 Post subject:
Unread postPosted: Wed Jul 02, 2003 7:54 am
In general, would compiling software with MipsPro vs GCC yield a "faster" running program on the average 300mHz Octane or is there not enough difference to be noticeable?
Joe
