xmms transparent skins + a gtk/X11 question
squeen
Unread postby squeen » Wed Jun 18, 2003 6:42 am
A few xmms questions:
1) What does xmms play? Is it just MP3's, if so how do you create them from wav or aiff files on IRIX?
2) I selected the Sinistar skin on xmms. How did it achieve the transparency or non-rectangular windows? I believe there is a non-rectangular window X extension, is that the mechanism?
3) Why do the gtk apps seem to have less Expose events issues than the Motif based one? I discovered this while swipping the Sinistar skins over mozilla and gnumeric. Contrast the refresh "trails" to Netscape 4.7, Showcase or a large image in Imageview (or my own apps!). Does gtk force backing stores (under the IRIX Xserver)?
Dazed and Confused.
Hakimoto
MP3....
Unread postby Hakimoto » Wed Jun 18, 2003 10:18 am
You can use lame-3.91 for IRIX. Works wonders...
grace, elegance and style.
Re: xmms transparent skins + a gtk/X11 question
Unread postby dexter1 » Wed Jun 18, 2003 1:53 pm
squeen wrote:2) I selected the Sinistar skin on xmms. How did it achieve the transparency or non-rectangular windows? I believe there is a non-rectangular window X extension, is that the mechanism?
I don't know if this is "built-in", so to say. This shaped borders used to be around when i first tried enlightenment with Alien theme(1996). Back then, Enlghtenment relied heavily on Imlib, an image manipulation library. It's a combination of applying a maskcolor on your borderimages, and with some clever X11/Imlib tricks, one can achieve the desired effect.
