The Nekoware Tardist Build FAQ
Unread postby dexter1 » Fri Oct 29, 2004 5:11 pm
My first attempt at a FAQ for building tardists for nekoware. It's grossly incomplete, contains arrogant remarks, smells like dogpoo and is probably not very accurate. Please comment on this FAQ in the regular thread "Nekoware tardists build FAQ" started by O2ric and post suggestions! I'll be doing additions on this document in a hopeful steady rate. Hence my posting today, otherwise this will never get finished :)
collected by Frank Everdij aka dexter1 29 oct 2004
Intro
This is supposed to be a guide about making nekoware tardist packages to be enjoyed on SGI IRIX machines, aka those funny colored machines with a cube logo up front which costed a small car back in the days...
Rules
First of all we need to define some rules on what packages we intend to be released as nekoware and on what platforms they should run. We aim at opensource software, GNU GPL or BSD license or other free/non-commercial license, usually developed on linux x86 machines. Because these opensource software were mainly developed on x86 architecture, this poses some constraints on the target machine. It should have reasonably fast IO, fast integer performance and for building code it should run a recent MIPSPro compiler which can squeeze as much performance from code as it can.
As target SGI machines, we have chosen the following:
1) MIPS IV instruction set, meaning all machines with R5000 processors and up, which include: R5K Indy, R8K Indigo2, R10K Indigo2 Impact, R8K and R10K Challenge, R8K and R10K Onyx1, all O2, all Octane, all Onyx2, all Origin, Tezro, Fuel.
2) Minimum IRIX to run is 6.5.21m. On supportfolio you can get hold of 6.5.22m overlays, but take care to install Patch 5086 first if you plan to upgrade. People running less than 6.5.21 can use nekoware, but need some runtime modifications with RLD_LIST becuae of missing symbols, most notably strlcpy and strlcat. Ugly, but it works. Also take care to install the latest patches for the OS.
3) MIPSPro 7.4.x is the preferred compiler choice. Mipspro 7.3.1.3m is also pretty good and for some apps it's even better than the 7.4.x series. We discourage the use of gcc 3.x, though sometimes it is the only choice. Unsure is, if compiling c++ code with g++ will play with MIPSPro compiled code, because of name mangling issues.
4) IRIX 6.5.22m is our preferred build platform OS. This IRIX is the end of the line for a lot of older machines, has mp3 support, UDF, IPV6, NTP, in short a nice OS, is fairly recent, and if reasonably patched, quite stable.
Port/Compile
Porting opensource on IRIX platform is sometimes not an easy task. To name a few major problems:
1) Endianness. IRIX is big-endian, meaning that word/multiword storage starts with the most significant byte first. x86 PC's are little-endian. So you can have situations where you need to swap bytes around before or after processing variables in routines.
2) ASM. Forget it. Optimised x86 assembly code will never run on MIPS. Ditch the software and find a C/C++ equivalent.
3) GCC-isms. A name bundling a variety of hacks (void pointer arithmetics), oddball coding (namespace clashes), wrong standards (C++ iostreambuf return pointer), hard-coded Makefiles (the worst) and botched/ignorant ./configure scripts (even worse than worst). Sometimes switching to c99 instead of cc fixes a lot of gcc-isms. In the code atleast
4) Different device handling, most notably parallel port programming and audio. No joysticks :( no USB (except your mouse on the Tezro)
5) Performance/Speed. MIPS being a floating point killer has trouble with integer code. Most opensource code do not take this into consideration, so optimisations are needed to crank up the code to make it run at useable speeds on your IRIX box.
Minor problems like misplaced or missing headers can usually be fixed by a bit of searching and #ifdef's wrapping. __sgi is a nice symbol to use for that, though most ./configure scripts can determine that you're running MIPS and set defines accordingly. Also defines which include BSD in the name are sometimes a good idea, since IRIX is a BSD style Unix flavor.
Selecting a good environment is necessary to get a proper build. A good starting point is:
setenv CC cc
setenv CXX CC
setenv CFLAGS '-O3 -mips4 -n32'
setenv CXXFLAGS '-O3 -mips4 -n32'
setenv CPPFLAGS '-I/usr/nekoware/include'
setenv LDFLAGS '-L/usr/nekoware/lib'
CC is the basic C compiler environment name, which usually gets picked up by ./configure scripts. sometimes one may have to substitute it with:
setenv CC c99  (only for mipspro 7.4.x) or
setenv CC c89  to select a more gcc-like parsing and compiling behaviour.
CXX is the C++ compiler environment name. It should be CC or g++ if the code is too messy to compile with MIPSPro.
CFLAGS and CXXFLAGS should be small and neat. -O3 gives you the best optimisation for a first compile attempt. -mips4 selects MIPS IV instruction set optimisations. -n32 select 32bit addressing, so pointers should not exceed 2 Gb, which rarely happens with opensource programs.
/usr/nekoware/include and /usr/nekoware/lib should be good include and lib paths for porting an app to nekoware. If you need more libs to port an app, it may be an idea to first build it into /usr/local, so you can test the code before doing a proper nekoware build.
Other less used environment variables which can be picked up by ./configure are
setenv PERL /usr/nekoware/bin/perl
setenv GNUMAKE /usr/nekoware/bin/gmake
setenv SED /usr/nekoware/bin/sed
Packaging
Try to start ports with the necessary prerequisites installed, preferably nekoware packages if you plan to make a nekoware tardist. Although nekoware doesn't bite with freeware, some ./configure scripts can get confused with two similar named libraries in different locations. Imagine a package including /usr/freeware/include/jpeg.h and linking with /usr/nekoware/lib/libjpeg.so...
So it's best to dedicate a machine for that.
I compile most opensource stuff for nekoware in /usr/local/src/<programname-version>
For building packages i have made a directory /usr/local/src/build and in there i make a directory <programname> where i store the following; Lets give and example for the program called "program" In /usr/local/src/build/program :
1) neko_program.idb <- swpkg/gendist package list of files and actions
2) neko_program.spec <- specification file of subsystems, versions and dependencies
3) neko_program.txt <- text file with specifications on the build proces, program version, used environment variables, ./configure options, dependencies needed, background info, sometimes test results or performance numbers.
4) program-1.2.3.tar.gz or program-1.2.3.tar.bz2 <- original program tarball. Always leave the tarball intact, because the source code and copyright notice should remain available.
5) neko_program-1.2.3_irix.patch <- patch file to patch the source. should be a cat of diff -u output applied inside the source path /usr/local/src/program-1.2.3 so it should be appliable with "patch -p0 < neko_program-1.2.3_irix.patch"
6) clean.txt and program.txt <- These are ls -lR outputs of /usr/nekoware done as root, before and after a "make install" so i know what files have been added/deleted by doing a diff or xdiff of these two files.
5) and 6) are more or less my choices but 1) through 4) are mandatory files and should be included in the nekoware tardist build so people can recreate the tardist if needed.
More to come after my beauty sleep :)
whiter
Unread postby whiter » Tue Jul 11, 2006 7:49 am
Is your beauty sleep done yet?
regan_russell
Unread postby regan_russell » Fri Dec 01, 2006 1:33 am
Ok, let me see if I have this straight.
First build packages using the rules in the previous post, target R5000 and above, etc, IRIX 6.5.22 and above, etc, port/compile with preferably MIPSpro 7.4.x, etc...
After that use nekotool to create template with the values given in environment variables:
NEKOPKGNAME name of the packages, e.g. gtk for neko_gtk
NEKOPKGVERSION version of the package, e.g. 2.7.5 for neko_gtk
NEKOBUILDER name of the package-builder, e.g. Tobias Paprotta
NEKOBUILDERCONTACT contact information for the package-builder,
e.g. (mailto:paprotta@nano.uni-hannover.de)
After using nekotool to create *.idb, *.spec and *.test files use gendist to create the *.tardist file.
     gendist [ -rbase rbase ] [ -root rbase ] [ -sbase sbase ]
          [ -source sbase ] [ -idb idbfile ] [ -spec specfile ]
          [ -dist distdir ] [ -mr file ] [ -sa file ]
          [ -creator name  ] [ -verbose ] [ -maint ]
          [ -nocompress ] [ -nostrip ] [ -genidb ]
          [ -genspec ] [ -all ] [ -ignoreempty ] [ patterns ... ]
ant_39
what with the package?
Unread postby ant_39 » Sun Dec 10, 2006 6:56 pm
Hi... what is one supposed to do with prepared package? I took a liberty of simply trying to upload it to beta/ and incoming/ directories on nekochan ftp, but was out of luck in both cases. Is there some magic login/passwd combination that I missed, or some more formal process that I should adhere to?
joerg
Re: what with the package?
Unread postby joerg » Sun Dec 10, 2006 11:59 pm
ant_39 wrote:Hi... what is one supposed to do with prepared package? I took a liberty of simply trying to upload it to beta/ and incoming/ directories on nekochan ftp, but was out of luck in both cases. Is there some magic login/passwd combination that I missed, or some more formal process that I should adhere to?
In the past the incoming directory has write access for anonymous... but maybe Pete have change that. For the other directorys you need an account with password. So if you have a bunch of packages please send a PM to Pete (nekochan owner) and ask for an account. Otherwise send me your tardists with e-mail or provide an url for download so i can take a look first ;)
regards
Joerg
Unread postby nekonoko » Mon Dec 11, 2006 12:02 am
joerg wrote:In the past the incoming directory has write access for anonymous...
Still does. But it's a "drop box" - you won't be able to get a directory listing in there, and you can only upload files. This is done for security/abuse reasons.
joerg
Unread postby joerg » Mon Dec 11, 2006 12:09 am
Thats what i expected :). Maybe the users are confuses because they cant see the directory listing.
regards
Joerg
Alver
Unread postby Alver » Mon Dec 11, 2006 3:33 am
Not just that. Some ftp apps (gftp, for one) simply won't work with directories it can't list. Probably a lil bug, but at least I had to revert to good ol' commandline ftp to upload stuff there...
while (!asleep()) sheep++;
ant_39
Ok, woks!
Unread postby ant_39 » Mon Dec 11, 2006 3:05 pm
I must have mistyped the path yesterday, I've just tried it now (with console ftp, just as yesterday) and the file (neko_expect-5.44.1.tardist) was accepted in incoming.
squeen
Unread postby squeen » Sun Dec 31, 2006 3:45 am
See also the wiki page.
Reason: edited link to point to correct site
