It is currently Thu May 23, 2013 12:35 am
Post new topic Reply to topic  [ 4 posts ]
Unread postPosted: Sun Apr 04, 2004 1:16 am
I just finished the optimized GTK+-2.4.0 build with MipsPro (look here :)) and am packaging it but encounter some weirdness with gendist. It is unable to parse the 'exp' (for example "exp nekopro_gtk+.sw.base") lines in my .spec file because of the "+".
But I see packages like "ifl_eoe.sw.c++" from SGI itself. How can you make gendist understand the "+" characters !???
Unread postPosted: Mon Apr 05, 2004 1:19 am
I worked around that problem once by editing the .spec file and adding double quotes ("")around the product name.
Erik
 Post subject:
Unread postPosted: Mon Apr 05, 2004 2:05 am
well... I tried that ofcourse. Also tried escaping the characters. But none of that works here. gendist keeps complaining.
 Post subject:
Unread postPosted: Tue Apr 06, 2004 12:49 am
Then I'm not sure I'll be able to help here.
I tried to search for it without any luck and my attempts are at least two years old.
Sorry.
Erik
