It is currently Wed May 22, 2013 2:44 am
Post new topic Reply to topic  [ 8 posts ]
 Post subject: Unusual compiler warning
Unread postPosted: Wed Mar 10, 2004 7:28 am
Has anyone seen this kind of error before.
Code:
ld32: FATAL   11 : Object file format error (./models/redux.o): missing section headers
It pops up from time to time on my project -- specific to that one file, but goes away when I make clean and rebuild all. I'm using gcc, because MIPSpro complains about my lex
file with the following:
Code:
cc-1047 cc: WARNING File = /usr/include/sys/termios.h, Line = 319
  Macro "ECHO" (declared at line 39 of "lex.yy.c") has an incompatible
          redefinition.
  #define       ECHO    0000010
cc-1167 cc: WARNING File = console.l, Line = 343
  Pointer points outside of underlying object.
  yycrank+-1,   0,              0,
cc-1167 cc: WARNING File = console.l, Line = 344
  yycrank+-4,   yysvec+1,       0,
cc-1167 cc: WARNING File = console.l, Line = 349
  yycrank+-3,   0,              yyvstop+11,
cc-1167 cc: WARNING File = console.l, Line = 359
  yycrank+-4,   yysvec+7,       yyvstop+40,
worse yet, when I try to use flex I get ERRORS:
Code:
cc-1171 cc: WARNING File = console.l, Line = 85
  The indicated expression has no effect.
  ECHO;
cc-1018 cc: ERROR File = lex.yy.c, Line = 1169
  An unmatched left parentheses "(" appears in an expression.
  static int input()
cc-1143 cc: ERROR File = lex.yy.c, Line = 1169
  Declaration is incompatible with "char *line_read" (declared at line 29 of
          "console.h").
  static int input()
cc-1065 cc: ERROR File = lex.yy.c, Line = 1171
  A semicolon is expected at this point.
cc-1012 cc: WARNING File = lex.yy.c, Line = 1198
  Parsing restarts here after previous syntax error.
                        *yy_c_buf_p = '\0';
cc-1166 cc: ERROR File = lex.yy.c, Line = 1200
  Expected a declaration.
                else
cc-1012 cc: WARNING File = lex.yy.c, Line = 1225
                                                return 0;
cc-1166 cc: ERROR File = lex.yy.c, Line = 1226
                                        else
cc-1012 cc: WARNING File = lex.yy.c, Line = 1241
                                        yy_c_buf_p = yytext_ptr + offset;
cc-1166 cc: ERROR File = lex.yy.c, Line = 1242
                                        break;
cc-1166 cc: ERROR File = lex.yy.c, Line = 1243
cc-1012 cc: WARNING File = lex.yy.c, Line = 1247
        c = *(unsigned char *) yy_c_buf_p;      /* cast for 8-bit char's */
cc-1077 cc: ERROR File = lex.yy.c, Line = 1248
  The indicated declaration has no storage class or type specifier.
        *yy_c_buf_p = '\0';     /* preserve yytext */
cc-1143 cc: ERROR File = lex.yy.c, Line = 1248
  Declaration is incompatible with "char *yy_c_buf_p" (declared at line 219).
cc-1077 cc: ERROR File = lex.yy.c, Line = 1249
        yy_hold_char = *++yy_c_buf_p;
cc-1143 cc: ERROR File = lex.yy.c, Line = 1249
  Declaration is incompatible with "char yy_hold_char" (declared at line 211).
cc-1057 cc: ERROR File = lex.yy.c, Line = 1249
  The indicated operator is not allowed in a constant expression.
cc-1077 cc: ERROR File = lex.yy.c, Line = 1251
        yy_current_buffer->yy_at_bol = (c == '\n');
cc-1143 cc: ERROR File = lex.yy.c, Line = 1251
  Declaration is incompatible with "YY_BUFFER_STATE yy_current_buffer" (declared
          at line 201).
cc-1065 cc: ERROR File = lex.yy.c, Line = 1251
cc-1166 cc: ERROR File = lex.yy.c, Line = 1253
        return c;
cc-1166 cc: ERROR File = lex.yy.c, Line = 1254
cc-1012 cc: WARNING File = lex.yy.c, Line = 1368
  extern int isatty YY_PROTO(( int ));
cc-1042 cc: ERROR File = lex.yy.c, Line = 1424
  The types of operands "YY_BUFFER_STATE" and "int" are incompatible.
        if ( b == yy_current_buffer )
18 errors detected in the compilation of "lex.yy.c".
any old school IRIX lexers out there willing to teach me the enlightened path? :)
 Post subject:
Unread postPosted: Wed Mar 10, 2004 8:32 am
if you could specify which package you're trying to build, we might be of some help :)
I'm not impressed by the multitude of compiler errors on MIPSPro output. It usually is a wrong declaration (inline or something similar) which cascades through your source file...
 Post subject:
Unread postPosted: Wed Mar 10, 2004 9:02 am
Sorry dexter1, I didn't mean to litter ;)
The application is my own. It was developed up to now compiling with gcc (because of the lex warnings). Everything goes together OK. I just today switched over to MIPSpro in preparation of compiling -64 to use 128 bit precision in the calculations. My questions are:
a) what does that linking error mean? -- what has become garbled in the code that a rebuild clears out?
b) does MIPSpro C work with flex?
Thanks...and sorry -- everything I do is rushed these days. :(
 Post subject:
Unread postPosted: Wed Mar 10, 2004 3:37 pm
I have no clue whatsoever about the linker error. Do you use fancy flags when compiling? -Ofast? -IPA? -TARG:? Do you use archives, maybe?
As for the flex errors, try to look hard at the function "input", looks like it's been redeclared in the c code, which conflicts with a previous prototype header. Compile gcc with -ansi -pedantic and see if it blurts more warnings about that function.
Unread postPosted: Thu Mar 11, 2004 1:12 am
Code:
This isually happens when the linker gets terminated while generating the object file. Removing that particular file and rebuilding should work.
Erik
 Post subject:
Unread postPosted: Thu Mar 11, 2004 3:21 am
:shock: Thanks SkyBound! (you too dexter1)
 Post subject:
Unread postPosted: Thu Mar 11, 2004 3:26 am
And another Dutchy!
Welcome SkyBound :D
 Post subject:
Unread postPosted: Thu Mar 11, 2004 10:40 am
whiter wrote:
And another Dutchy!
Welcome SkyBound :D
Yeah thanks. Event the location is the same :P
Actually I've been reading most of the posts for some time now.
This is the first post though.
Erik
cron
